Results 1 to 17 of 17
Thread: All over the road
01-01-2008, 06:07 PM #1
All over the road
I dont know what is wrong. Anything over 50mph and really bad when you let off the gas. The fucking thing is all over the road. New--- front sway bar links, sway bar bushings, front lined up(sears). New rear sway bar bushings both panhard bars are on. Replaced Front struts with used. My car only has 43,000 miles. Please help me it's not even fun to drive. It suckes.
01-01-2008, 06:38 PM #2
- Apr 2007
- Bentonville, AR
Navy Blue Metallic- '02 Trans Am WS6
Don't take this the wrong way, but did you have an alignment done after installing those pieces?
01-01-2008, 10:32 PM #3
Did you experience same respond/problem before you replaced the stuff?
01-01-2008, 10:50 PM #4
do you mean all over the road like pulling to one side, or like the car is grabbing every rut in the road and pulling you all over the lane? In either case, get the alignment checked.
Tires (make/size etc) can sometimes cause the grabbing of the ruts as well
01-11-2008, 11:41 AM #5
- Oct 2007
- NC
SOM- 1998 T.A.
These cars have a tendency to "trammel" which is what I think you are describing. I always get caster and camber confused but if you run a slight negative caster (I think it is) on your alignment it will not be as bad. Don't run too much or your tires will wear. It basically points both tires in just a hair.
01-12-2008, 06:12 AM #6
- Apr 2007
- Watertown, New York
Navy Blue Metallic- 2002 Z28
Nope, you have it mixed up, Camber is the amount the top of the tire is in relation to the bottom. Caster is the same effect of a caster of a shopping cart. That effects how your steering turns back by itself after going around a corner and such.
But I really cant help you without more details, maybe you have trashed strut bearings, the used struts you put on are junk, you need an alignment, something didnt get installed correctly, you have a broken part, the list goes on....
01-21-2008, 10:36 AM #7
- Jul 2006
- tx
white/black- 2002 Camaro Z28
I have experienced the same thing.. in my case.. it is the tires.. that grab any irregularities in the road. I have noticed that as the front tires wear, the problem becomes worse. Alignment has nothing to do with it in my case.. but i am running 275/40/17 in front.. i am thinking that the tire is just so wide that it tends to follow the road.
01-21-2008, 10:38 AM #8
wow thats a reaaallll wide tire for the front, some people run those in the rear
01-21-2008, 06:41 PM #9
01-22-2008, 12:54 AM #10
- Jun 2002
- Montreal, CANADA
Eugenio_SS
01-22-2008, 06:00 AM #11
- Jul 2006
- tx
Hey Eugenio.. do you experience the same thing with your ride? What tires do you run on your setup? nice ride btw..
01-22-2008, 06:07 AM #12
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
My SS has the 275s up front and the tires well pull when there is groves or depressions in the pavement. It did it before and after all my suspension mods.
I have a 79 Corvette with 255s up front and its does the same thing. I’ve been told that directional tires experience this worse then non-directional tires do.1998 Camaro SS Hard Coupe Bright Red #1593
Mods: Lots!!, still my daily driver except for winter
383rwhp 370rwft/lbs
1979 Corvette
Mods Lots!!, weekend cruiser
325rwhp and 320rwft/lbs
2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
Mods: Catback, BFI CAI, Winter daily driver
01-24-2008, 10:54 PM #13
01-27-2008, 06:06 PM #14
- Dec 2005
- Huntington Beach, California
navy blue metallic- 2001 trans am
he needs to tell us about his tires. I bet they are skinny 275s and worn. Get some new tires and a fat swaybar are itll be bitchen
01-28-2008, 07:12 AM #15
01-28-2008, 12:25 PM #16
01-28-2008, 07:33 PM #17
Our road car
By FishinCricket in forum Member's RidesReplies: 4Last Post: 04-16-2012, 07:54 AM -
Crusher Camaro Road Trip - Road Kill
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 03-26-2011, 12:30 AM -
off road suv's= off road computers?
By Ramairgod84 in forum Almost Anything GoesReplies: 6Last Post: 05-18-2010, 01:08 PM -
Question: A little later down the road........
By Dave-TransAm in forum Firebird / WS6Replies: 11Last Post: 01-21-2010, 05:20 AM -
What you do when you see another T/A on the road?
By freddy_caprice in forum Firebird / WS6Replies: 70Last Post: 05-21-2009, 08:38 AM
