Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21
    Member performabuilt's Avatar
    SUGAR LOAF PA
    blue
    2000ss
    PerformaBuilt 4L80E BUILD PART 2
    4l80e Build Part 2
    Intermediate clutch installed
    Direct clutch drum and Intermediate overun band installed. I have found its easier to install the drum without the clutch set first. Then install the set as shown below
    Make the drum easier to hold on to when indexing the Intermediate clutch set to it.
    Forward clutch assemby
    Forward clutch assembled
    Forward clutch installed in case and indexed into the direct clutch, The billet shafts are a tight fit and makes the indexing a little agravating.
    Overun and overdrive clutch drum
    Overun/overdrive drum with frictions installed
    OD assembly ready to install
    OD assembly installed into the case.
    Installing the Stage 1 overdrive frictions and new steels
    OD clutches installed complete.
    Close up of billet input shaft from CK PERFORMANCE.
    Pump installed
    Pump installed with new front seal
  2. #22
    SUGAR LOAF PA
    blue
    2000ss
    Case valve body channels with od and center support bolts installed.
    Case VB channels with low/reverse and intermediate overun servos along with check ball installed.
    Well thats all I have till tomorrow I will be finishing up then and preparing to dyno . Will post more pics in a couple days
  3. #23
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    so what power level will this hold,seems my stage 3 4l65e wont hold up so whats this one do?
  4. #24
    SUGAR LOAF PA
    blue
    2000ss
    Well this one comes in two flavors lol the one listed on is rated at 1000 plus rwhp. This one I am going through the build for 1500 plus. But I must tell you putting one of these in a GOAT from what I have gathered is a pain. And the 05-06 computer with these is a major issue also.
  5. #25
    2005 GTO
    so whats a pain about it?do away with tcm and use vac mod..I am so fnin tired of putting in and pulling out the 4l65e
  6. #26
    SUGAR LOAF PA
    blue
    2000ss
    I think your giving the VAC MOD to much credit, It contrary to some peoples understading will not cause the trans to shift it simply replaces the PCS not the TCM, However if you dont mind going full manual valve body then the electronics at least are not and issue, But all auto functions will be lost and you will still need to wire up a way to have lockup.
  7. #27
    2005 GTO
    ok so what do you suggest,I would rather have it controled by tcm,its a street car.
  8. #28
    2005 GTO
    I am the current great lakes record holder will someone make me a deal or sponsor me with a trans that will hold 1000-1200hp? best et on stock ls2 with 12 psi 10.9 at 128mph,i want to put in my new 408 but cant rely on stage 3 4l65e,somebody help me!
  9. #29
    2005 GTO
    update 10.6 at 129 1.64 60ft..with drag radials..
  10. #30
    2005 GTO
    Quote Originally Posted by performabuilt View Post
    why cant i use a aftermarket TCM? I want the auto functions if at all possible...
  11. #31
    SUGAR LOAF PA
    blue
    2000ss
    You can use the after market TCM and by the way we will be calling you monday
  12. #32
    2005 GTO
    great cant wait to go faster!
  13. #33
    2005 GTO
    any chance to give me some info on that 4l80?
  14. #34
    Dec 2008
    Metro Detroit, MI
    1999 Blazer LS 2DR
    The 5th picture shown is a device called a case saver. It replaces the stock anti clunk spring and more evenly distributes shock against the case lugs. This helps to prevent excessive lug wear in the case or breakage of the case or lugs.
    That is a badass idea. Plus i can never figure out which way the damn spring goes. I've built about 10+ 4L60Es/700R4s by myself, and my uncle has to show me time and time again. Lol im a dumbass.
    But still thats a sweet idea! Do you guys make those yourself or can you buy them?
  15. #35
    SUGAR LOAF PA
    blue
    2000ss
    They are readily available from any trans parts supplier.
    FREE COOLER/SHIPING, NO CORE OR CHARGE,2YR WARRANTY, CUST TRACK VIDEOS click banner 4 website, CALL or text 570-578-5686 7 days a week 9 am till 10 pm.
  16. #36
    NYSpeed.com WhatUpWhatUp's Avatar
    Oct 2009
    NeW YorK
    2002 z28 A4
    Thumbs up
    great info and pics !!
  17. #37
    2005 GTO
    lil update,the 4l80e is just as easy to slide in a GTO as the stock trans,you have to have the new converter for the 80,decide if you want to use a manual valve body or a electronic shift,I have a seperate TCM,which is programable and controls the trans shifts.other then the drive shaft and alil mod to the cross member,the 4l80e is a way better choice for us high power guys in the GTO, since its a heavy car it will eat those weak lil 60/65s no matter who build the dam things , anyone lets say above 550hp might as well upgrade to a way better trans,my car went 9.52@144mph,weight with driver 4270lbs, im very happy with both my PERFORMABUILT 4l80e and their customer service,is the shit,Frank will take care of you! I just glad to have a trans I dont need to tear out every 30-50 passes.
  18. #38
    Junior Member speedfreak1's Avatar
    Mar 2011
    Parma,Ohio
    I just picked up a performabuilt level 2 and a fti converter will be putting them in next week. I will post up how well it works. 4l60e
  1. Performabuilt or finish line transmissions?
    By seth_12 in forum Automatic Transmission
    Last Post: 11-07-2011, 01:01 PM
  2. PerformaBuilt Transmissions
    By Flash00TA in forum Automatic Transmission
    Last Post: 03-21-2011, 01:33 PM
  3. PerformaBuilt Transmissions Post Labor Day SALE!
    By performabuilt in forum Automatic Transmission
    Last Post: 09-08-2009, 09:39 AM
  4. New To Transmissions....
    By JwMonE99 in forum V6
    Last Post: 12-03-2006, 10:40 AM
