Results 41 to 60 of 78
02-24-2010, 06:52 PM #41
The suspension parts were on sale for a week that is why they went up.
the clutches went up from my dealer also.
Thanks,
Mark
02-28-2010, 09:48 AM #42
03-08-2010, 06:25 PM #43
Mark- I meant nothing negative toward you or KYSpeed- you're one of the best vendors I've ever dealt with and appreciate the time you dedicate to making sure your customers are treated right and leave happy. I just think it sucks that in this economy UMI has gone up as much as they have. I assume it's mostly on the supplier end, but it's bad that they end up leaving their vendors to have to explain 15-30% markups since November. Once again, thanks for all the great service in the past and I look forward to buying all my suspension stuff from you this summer.
03-08-2010, 06:54 PM #44
No problem
thanks for the kind words also.
look forward to doing business with you in the future.
Thanks,
Mark
04-19-2010, 08:06 PM #45
- Apr 2010
- washington
- 2000 trans am ws6
has anyone heard of the ls9x clutch i saw it here on the website http://katechengines.com/katech_inc/...-ls2ls3ls7.htm
i was wondering if it my 2000 trans am
12-30-2010, 07:19 AM #46
- Jul 2010
- sc
black- 1998 camaro
Price
does this come with everything and is it a good price
http://www.gmpartsdirect.com/results...c6ls7clutchkit
Thanks
12-31-2010, 09:34 AM #47
You still need the slave cylinder, pilot and throwout bearings, and I'd suggest upgrading the master cylinder as well. One other thing to get is an alignment tool- got mine at a local parts store for less than $4.
2000 Pontiac Firehawk #0041 of 742
01-01-2011, 08:12 PM #48
Will the LS7 clutch hold 400RWHP as a dialy driver? Or should I look for something else?
01-01-2011, 08:25 PM #49
02-20-2013, 04:00 PM #50
I have a 98 Trans am in need of a new clutch. I know the Ls7 has more than enough holding power for what I am getting at the rear wheels. My questions is about the flywheel. I want to upgrade to an aluminum or a billet steel one. From what I understand both will be much lighter than my stock one. When I get a LS7 clutch do I need to get a LS2 or LS7 flywheel or can I use an LS1 flywheel. There is no price difference I just want to make sure I have all the right parts. Thanks for your help I know this is an old thread
02-20-2013, 04:26 PM #51
Most vendors sell them as a kit. I got mine from KYSpeed. Cost $500 at the time. It comes with new fly wheel, pressure plate & clutch. IIRC it came with the LS2 flywheel. The difference is thickness of the plate. I believe all GM flywheels are made of steel, except special order items.
Ive been very happy with mine.
Items recommend to do now if funds availible:
New gm slave cylinder. Best to do it not vs later
Speed bleeder from Tick Performance
Tick Master Cylinder - if you plan on upgrading the mc this is the best option. GM's mc has it's issues. The other reason is with the LS7 clutch it is self adjusting as it wears. Ppl have reported having issues with the Tick mc & LS7 clutch that has had wear. If the mc is installed at the same time as the clutch, no issues.
Difference between AL vs steel. Need to ask yourself is it really worth it? What I mean is can the money be spent on something else. Having an aluminum flywheel is nice but if you only go to the track every so often then not really worth it.
02-21-2013, 09:50 AM #52
Whats the main difference between billet steel vs aluminum vs stock flywheel?
Will my original MC work ok with the new LS7 set-up? Unil I can spend another $350 on a Tick MC?
I am planning on getting a slave cylinder does that have to be a LS1 or LS7/2 when I order?
02-21-2013, 02:30 PM #53
- Apr 2008
- Madison, WI
Weight and strength. Light flywheels rev up faster, heavy flywheels carry more momentum (ie easier street driving)
Yes
Stock LS1 for your car. Get a GM one, not some cheap aftermarket one from Autozone.
02-22-2013, 09:58 PM #54
I've had my LS7 clutch kit for three years now and it's still holding strong (very little time at the track, almost all in city driving and 425 HP). Definitely go GM for the slave, as difficult as they are to change out (have to drop the trans and bell housing), I'd hate for to have to do the job a second time simply because some aftermarket slave cylinder decided to crap out on me. The only problem I've had is my GM throwout bearing squeaks.
Don't forget to also get a rear main seal and housing gasket- might as well change it while you have the chance. The biggest pain is removing the pilot bearing. I ended up using a carbide bit on a dremel to grind out a notch in it so I could split it in half and it popped right out. Tried this after breaking two pilot bearing removal tools.
02-25-2013, 10:55 AM #55
Does anyone know what the part number for just the LS7 clutch with pressure plate is? Its a nightmare trying to search gmpartsdirect without a part number
02-25-2013, 10:56 AM #56
On the rear main seal is says there is a double lip and a triple lip. Which one do I get?
02-25-2013, 11:41 AM #57
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I have done all the research and have been ordering parts and putting parts together so here is your list for gm parts direct-
Ls7 clutch # pkc6ls7 $418.79 clutch package with flywheel
Gm slave. # 24264180 $117.33
Gm rear cover gasket. # 12639249 $15.07
Gm rear main seal. # 89060436 $13.71
Gm pilot bearing. # 14061685 $11.68
ARP flywheel bolts- summit racing-- $32.13
ARP pressure plate bolts - summit racing- $17.66
Tick master cylinder - $324.99
Tick speed bleeder - $49.99
T56 inputshaft seal - sku1300-044-015 $14.99 - tick performance - tranny out change it also
You are looking at just under $1,100.00 for everything with shipping.
This should help you out
02-25-2013, 11:48 AM #58
- Apr 2008
- Madison, WI
I'm in the "If it ain't broke, don't fix it club." I don't see any need to change the rear main and trans input seal if they aren't leaking. Pilot bearing I'd probably change. I'd also skip the speed bleeder. The mity vac bleed at the reservoir works well.
02-25-2013, 12:07 PM #59
02-25-2013, 12:10 PM #60
Perfect that will make things way easier
DO ANY BODY HAVE INFO ON THIS? Neohydro Technology
By craigsws6 in forum Forced InductionReplies: 14Last Post: 11-27-2009, 05:57 AM -
Body kit info
By JB454 in forum Appearance SectionReplies: 2Last Post: 05-19-2009, 11:43 PM -
2001 Trans Am Clutch info
By locodave in forum Manual TransmissionReplies: 4Last Post: 10-01-2006, 06:04 AM -
ls7 clutch info
By 1999z in forum Manual TransmissionReplies: 7Last Post: 09-17-2006, 06:16 PM -
Need info/help w/clutch hydraulics and new clutch
By OreoLt1 in forum DrivetrainReplies: 5Last Post: 03-11-2006, 05:16 AM
