Results 21 to 40 of 78
08-30-2008, 09:17 AM #21
08-30-2008, 09:21 AM #22
09-02-2008, 08:03 AM #23
I'm thinking about putting a LS7 behind my new forged motor w/roughly 415WHP and of course I can't forget to mention wanting to run a 2 stage nitrous 150+100 setup. I'm running a single stage @ 150HP right now.
Needless to say, the stock LS6 clutch served me well for 1.5 seasons, but its DONE now. Time to upgrade.
Thoughts? I'm betting that I'll the LS7 isn't enough for my requirements. Oh BTW, I don't want pedal pressure like a dump truck either...
-Eagle
09-02-2008, 09:42 AM #24
- Mar 2007
- Gainesville, VA
One more thing to remember about the LS7 clutch is it's designed for a much lighter car. I personally would not use it in anything more then a full bolt-on car.
09-02-2008, 04:01 PM #25
10-30-2008, 09:23 AM #26
- Sep 2008
- IL
Red- 2001 Z06
LS 7 clutch
I have a PowrMax LS 7 with 575 RWTQ in my 2001 ZO6 and use the RPS Street Twin Carbon Fiber set-up. Pedal power is near stock and the clutch is rated to 800 HP. Yes, it's costley, but you only need to install one clutch. http://www.carolinaclutch.com/ShowItem/110668.aspx
10-17-2009, 09:30 PM #27
Does anyone have the GM part numbers for the LS7 clutch and the flywheel needed to put this setup in a F-Body? Anywhere you'd suggest going to buy them?
10-18-2009, 05:54 PM #28
- Apr 2008
- Madison, WI
check out one of our sponsor, Kentucky Speed. They have what you need.
KY Speed
10-23-2009, 10:53 PM #29
Thanks!
01-17-2010, 06:12 PM #30
Excuse my ignorance...Is this a GM product? If so, does anyone know the part numbers? Do I need to replace anything else when using this kit? Is it a kit or does it have separate part numbers? I have a 1999 Trans Am and I am changing out the clutch for the first time after 89k.
Any help is appreciated!
Thanks.
01-17-2010, 08:30 PM #31
Here's what you'll need:
LS7 kit (clutch, pressure plate, and flywheel)
Pilot bearing
Slave Cylinder (comes with throwout bearing)
Master Cylinder
Optional stuff:
ARP Flywheel and Pressure plate bolts
Tick Master Cylinder
Tick Speed Bleeder
Rear main seal (might as well change it while you have it out- also check your input shaft seal on the trans, it can leak as well and Autozone has a seal for under $10)
Supplies:
Oil
Dex Trans Fluid
Dot 3 Brake Fluid
Silicone sealant (for sealing the shifter back down)
Red Loc-Tite/ Threadlocker
Tools you DEFINATELY need:
- For the most part you'll need 10, 13, and 15 mm sockets but make sure you have a shallow 13 and 15mm u-joint socket to remove the trans and bell housing.
- A VERY long extension for your ratchet to reach the topmost bolts that hold the trans to the bell housing.
- Clutch alignment tool - picked one up from O'Reily's for $6.
You can order the clutch kit and slave cyl from Kentucky Speed. If you want to spring for it, go ahead and get the Tick MS and speed bleeder from Kentucky Speed as well. I highly recommend them both, but no matter what, get the bleeder. It will make your job infinitely easier. The pilot, seal, and master cyl (if you go with the stock one) can be picked up from GMPartsDirect. Everything else can be picked up from Summit Racing or a local speed/auto supply shop.
01-17-2010, 08:40 PM #32
Thanks man... Is the kit a GM product?
01-18-2010, 08:22 PM #33
Yes, it is a GM kit.
01-19-2010, 06:01 AM #34
Thanks bberretta... ordering it today! My clutch has been shot for so long it is going to be like driving a different car!
01-19-2010, 06:57 AM #35
Same thing here- I bought the car with a bad clutch. It had 128k on the original clutch and when I swapped it out I took it for a test drive and was shocked at how good it hooked up. It took a few days to wipe the grin off my face...
02-21-2010, 01:30 PM #36
hey just noticed kentucky speed upped the price..
LS7ClutchKit GM LS7 Clutch Kit $500.00
anyone know where i can get it for 400? seems pretty crazy to me the price going up instead of down after a couple years..
02-21-2010, 06:40 PM #37
02-23-2010, 10:59 AM #38
Got my LS7 Clutch kit form KY-Speed last week. I need some off work and bay time schedule so I can put it in.
02-23-2010, 08:16 PM #39
02-23-2010, 08:47 PM #40
Here you go:
http://www.ls1.com/forums/showthread.php?t=129118
I posted a bunch of pics and a pdf template for the brackets. I will most likely go back and re-do the brackets with thicker sheetmetal.
DO ANY BODY HAVE INFO ON THIS? Neohydro Technology
By craigsws6 in forum Forced InductionReplies: 14Last Post: 11-27-2009, 05:57 AM -
Body kit info
By JB454 in forum Appearance SectionReplies: 2Last Post: 05-19-2009, 11:43 PM -
2001 Trans Am Clutch info
By locodave in forum Manual TransmissionReplies: 4Last Post: 10-01-2006, 06:04 AM -
ls7 clutch info
By 1999z in forum Manual TransmissionReplies: 7Last Post: 09-17-2006, 06:16 PM -
Need info/help w/clutch hydraulics and new clutch
By OreoLt1 in forum DrivetrainReplies: 5Last Post: 03-11-2006, 05:16 AM
