Results 21 to 40 of 136
07-01-2007, 02:40 PM #21
07-01-2007, 04:13 PM #22
Yep had a set of Sumitomo's shipped to my door for $420. 275's up front 315's out back. I cant complain about the price and it got my ZR1's on the Z. No more snowflakes
07-01-2007, 07:30 PM #23
- Jul 2007
- richmond, illinois
blue- 99 trans am m6
so i heard you cant run 315's on 9 inch rims, i mean can you or cant you? if i grind down the bump stop and use a big fricken hammer will they work, or do the tire just not fit the rim?
07-02-2007, 05:42 AM #24
07-04-2007, 03:58 AM #25
- Jun 2002
- Montreal, CANADA
rear only makes me laugh... there is more room in the front that in the rear, even w/ turning into account...
Eugenio_SS
07-04-2007, 11:37 AM #26
07-05-2007, 06:06 AM #27
07-05-2007, 06:29 AM #28
- Apr 2006
- Fayetteville, NC
NBM- 1999 Trans Am WS6
This is a good thread! I recommend stickey as well!
07-05-2007, 11:06 AM #29
Sumitumo's are like 109 at Tirerack and are definately the cheapest. I have them on my ZR1's however for some reason they don't look near as wide on my car as those on his. Good post I had to learn the hard way about all of that especially the part about the lowered car went through 2 tires before I fixed it.
07-05-2007, 06:30 PM #30
I just ordered 2 315 Sumitumo's from TireRack and after shipping it was 225. Cant wait to put them on!
02 WS.6 --- Black w/ Red accents.... Cam, borla exhaust, and some other goodies....
07-16-2007, 07:23 PM #31
So is cutting and rolling the rear fender lips only required if the car is lowered? Does anyone have a "how to" on rolling the fenders?
07-17-2007, 04:24 PM #32
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
will the 315's fit on the my rear C5 Z06 rims? i had to hammer alittle to get the 295's in there. thanks
07-18-2007, 02:36 PM #33
I have 315/35/17 Nitto DR's with no issues, they never rubbed .......the BFG 315's DR's rubbed!
07-18-2007, 04:45 PM #34
Is anybody running 17x11 wheels with the 315 tires on a '97 or earlier f-body convertible? I'm running into some contraditory information regarding fitment of this set up on LT1 year convertibles.
07-19-2007, 12:07 PM #35
- Jun 2002
- Montreal, CANADA
plenty of LT1s w/ 315s can be found in www.frrax.com
They fit as easily in LT1 4th-gen than LS1 4th-gen... plenty of reading in perspective.... search will be your friend.
http://www.frrax.com/rrforum/index.p...=6134&hl=17x11
http://www.frrax.com/rrforum/index.p...=5930&hl=17x11
http://www.frrax.com/rrforum/index.p...=2160&hl=17x11
http://www.frrax.com/rrforum/index.p...=2922&hl=17x11
http://www.frrax.com/rrforum/index.p...=8213&hl=17x11
http://www.frrax.com/rrforum/index.p...=8364&hl=17x11
http://www.frrax.com/rrforum/index.p...=1179&hl=17x11
if you want 17x12 on all 4 corners, it works well as well:
http://www.frrax.com/rrforum/index.p...=4967&hl=17x11
there is more room in the front than in the rear, btw.
07-19-2007, 05:45 PM #36
Eugenio, Thanks for all the information.
Here's an excerpt from an Ebay ad from AFS for the ZR1s. It says they don't fit the 1993-1997 convertibles, but maybe they mean they don't without ANY modification (hammering, lip rolling)?
"AFS Corvette Wheels ZR-1 style 17 x11 Camaro Black
ITEM DESCRIPTION: This is a combination set of four new BLACK replica ZR-1 style rims with center caps. Please note these are not blemished wheels. This set has the new wider outer lip cut, giving them an updated look. There is NO RESERVE on this auction. Please see the pictures below.
WHAT THEY WILL FIT: They will fit '88 through '96 Corvette. They will also fit 1993 through 2003 Camaro/Firebird or Trans Am. They will not fit the '93-'97 Camaro, Firebird or TransAm 'Convertible'.
SIZE AND SPECIFICATIONS: There are two 17" x 9.5" (+56mm offset with 7.4" backspacing) rims for the front and two 17" x 11" (+50mm offset/7.93" backspacing) for the rear. These are the same as the Grand Sport offsets. The lug pattern is 5x120.65mm."
I addition to the information in this Ad, Tomz Wheelz would not give me a definite confirmation that the 11s (+50) would fit my car either.
Hopefully, you can understand my lack of clarity on this issue?
07-19-2007, 09:30 PM #37
- Jun 2002
- Montreal, CANADA
they say the same thing about LS1s... and it's BS.
Heck, GM even did not make the 17s available in 1998 on the convertibles... the SS had 16x8 ZR1 wheels.
It will fit.
08-25-2007, 09:54 PM #38
- Apr 2007
- Twentynine Palms, CA
Pewter- 2000 Formula 6spd
I have a lowered 2000 Formula. I'm putting 17x11 315/35 in the rear. Will I have to hammer the fender well and grind the bump stop as well?
08-28-2007, 05:08 AM #39
08-28-2007, 07:30 AM #40
- Aug 2007
- CT
Black- 2002 Trans Am
Blackwidow99... I have a 2002 WS6 with stock suspension and I am considering Torq Thrust Ms in the rear 17x10.5 (44mm offset) with 315-35-17s (possibly BFG KDWs). Do you think I would be able to fit them without hammering the wheel wheel or grinding the bumpstop? I would like to avoid doing that if possible. Thanks!
How to Make a 1998 Pontiac Trans Am Glow in the Dark
By Ed Blown Vert in forum GTOReplies: 1Last Post: 01-28-2014, 04:59 PM -
Question: does crager make rims to fit a 02 trans am
By carnut7202 in forum Wheels and TiresReplies: 4Last Post: 05-09-2010, 08:49 PM -
Question: What parts make WS6 package 02 Trans Am
By wmacarter in forum Firebird / WS6Replies: 23Last Post: 11-14-2009, 11:39 AM -
how to make a trans am look like a 240sx
By myk02k in forum Appearance SectionReplies: 15Last Post: 04-25-2008, 04:38 PM -
Wonderig if they make fender for the Lt1 trans am that look like Ls1(fenders with sco
By wicked illusions in forum Appearance SectionReplies: 0Last Post: 08-16-2005, 04:26 PM
