Results 1 to 20 of 57
Thread: visual guide for hptuners
05-01-2007, 07:34 PM #1
just something i am making as i have time. i am doing this to try and help people understand how to use it, or want to get an idea of what you can do before purchasing this product, or any other full tuning suite. this is not endorsed by hptuners.
http://tredalign.com/hptuners.htm
this is a work in progress. i may make more pages daily. i am open to suggestions and help in making this a decent guide.Last edited by mrr23; 09-28-2010 at 05:21 PM.
05-02-2007, 04:00 PM #2
Looking at getting hptuner. Where is the best place to get one. Best price and customer support. Thanks
05-02-2007, 04:06 PM #3
www.hptuners.com the place that makes it. customer support, hmmm the only thing they have is their forum. www.hptuners.com/forum and whoever is willing to answer your questions on this and other forums. which is why i'm making these webpages.
05-02-2007, 04:31 PM #4
today's episode:
How to remove Torque Management
How to remove C.A.G.S. (better known as skip shift)
05-02-2007, 04:54 PM #5
- Jan 2007
- Rhode Island
Arctic White Hardtop- '98 Formula M6
I just got a new laptop and I am seriously considering buying hptuners suite. what air/fuel gauge works the best with this?
05-02-2007, 05:09 PM #6
i'm getting the PLX through a group purchase on ls1tech. i think the LM-1 works as well.
05-02-2007, 05:46 PM #7
what would be my best bet in purchasing hptuner. the standard or pro. what do most ppl purchase?
05-02-2007, 06:39 PM #8
with the standard, you have to have the laptop in the car and running to log. with the MPVI PRO, the cable has the ability to log without the laptop connected. you can also connect external 5 volt reference devices, i.e. wideband, to the cable and log.
standard is $500.00
pro is $649.00
if you get standard and want to upgrade to pro, it's $300.00. so, it's cheaper to get the pro now. it's what i have.
http://www.hptuners.com/forum/showthread.php?t=2924Last edited by mrr23; 05-03-2007 at 04:30 AM.
05-03-2007, 04:11 AM #9
Thanks mrr23 i think ill be purchasing the pro here in a couple weeks. Any other advice for a new tuner like me. Wish me luck
05-03-2007, 04:29 AM #10
patience and have the ability to grasp things on your own. as they always say, start off with the little things and go from there.
05-03-2007, 04:33 PM #11
05-03-2007, 08:42 PM #12
I started looking at switching to HPtuners this week. I've been trying to hold out because I already have edit but right now trying to tune my cam with edit is kicking my ass. I'm about to give up on edit and move to hptuners but if I do that I also have to buy a new laptop which is really what's holding me back. I hate having to shell out $1k for tuning software and a laptop. My current laptop is only a 366mhz and although I could still use that to flash with hptuners I wouldn't be able to log. With the pro I could use the black box to log and technically get by for a while but then I wouldn't be able to use the live controls to make adjustments while the car is running which would suck. I'm gonna give it a few more shots with edit before I decide what to do.
05-04-2007, 07:28 PM #13
today's episode:
How to change your idle rpm
05-04-2007, 07:58 PM #14
next completed:
How to disable EGR
05-04-2007, 08:29 PM #15
05-05-2007, 02:27 PM #16
for idle, i don't see how you would feel a power difference. all you are doing is sitting there. sound? sure. if you want more lope to the engine, you lower the idle. you want a smoother idle, then you raise it. you want to play with this, when you change cams.
05-06-2007, 04:52 PM #17
Great writeups mrr23 check your pm's
Support for HPTuners
05-06-2007, 05:02 PM #18
thanks and responded.
05-06-2007, 10:26 PM #19
Keep up the good work
If you come in 2nd it just means you are the first to lose.
05-07-2007, 06:21 PM #20
today's update:
How to change when closed loop is enabled
a tuning guide i found based on hptuners
By mrr23 in forum Computer & TuningReplies: 15Last Post: 08-23-2022, 08:58 PM -
Android 4.2: A visual guide to what's new
By Ed Blown Vert in forum Computers / GamingReplies: 0Last Post: 11-23-2012, 11:50 AM -
Visual differences between ls1 and ls6 engine?
By pbguy357 in forum Firebird / WS6Replies: 20Last Post: 06-05-2011, 09:35 AM -
visual help
By V8MUSCLE in forum Wheels and TiresReplies: 3Last Post: 07-24-2009, 11:49 AM -
Possible Visual Mods
By JoshieDoom in forum Appearance SectionReplies: 2Last Post: 11-17-2007, 07:11 PM
