Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 155
  1. #41
    NW Chitown
    2002 WS6
    I'm doing the HSW 150 wet kit, the install fun begins this weekend. I've been told that as long as my timing isnt advanced (aka still stock) that I can run as-is without retarding it at all.
  2. #42
    Evr sena bdgr killa snak? Roastem's Avatar
    Research Triangle Park, NC
    '99 Z28 M6
    Quote Originally Posted by Eagle View Post
    Time slips please!
    And some pics of the install and final setup would be nice too...
  3. #43
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes you can but it will actually build more power on the bottle if it's retarded slightly.
    I would also recommend you run a AutoLite AR94 plug with the gap closed down to 0.040".
    I don't care what the directions tell you for the wiring....... Wire the solenoids so you are switching them on the ground side.
    That means you'll wire the relay opisite of normal. The solenoids will have constant power and the relay will be switching a GOOD ground to complete the circuit.
    This is for Eagles post about the 150 shot I forgot to " " it.
  4. #44
    NW Chitown
    2002 WS6
    Tuner-
    That raises a great question. I remember you saying that in so many posts, but I can't picture in my head how to wire the relays that way. Would you have a diagram handy by any chance? Because you're right, the diagrams all show the relay switching the + side not the - side...
    Thanks!
    -Eagle
  5. #45
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Tuner-
    Thanks!
    -Eagle
    I'll try to draw you up a diagram later tonight.
  6. #46
    NW Chitown
    2002 WS6
    Thanks man!
    -Eagle
  7. #47
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quickly this is it.
    # 30 is going to chassis ground NOT batt. power
    # 85 will go to Batt + FUSED
    # 86 will go to your arming toggle switch and the other side of the switch will be chassis ground...... So when you flip the switch it would complete the circuit. If you are using a WFO switch that wire would go in the middle.
    It's hard to explain here on the computer but if you are using both a WFO switch and a hand held button like I always do that button would be wired in this circuit. So when you hold dox=wn the button it is completing the ground to # 86
    # 87 will be wired to one of the wires off the solenoid
    And the other wire needs to go to batt. voltage on the solenoids. You can also fuse this wire for safety if wanted but not a must seeing that you fused #85
    You can wire them up and check your wiring by pushing the button or buttons and holding the relay first you'll hear an audable click then you can also wire to solenoids and hear and feel them actuate. You won't hurt them by cycling them to chaeck you wiring to make sure they work.
    DON'T OVER CRIMP TERMINALS LIKE SOOO MANY DO!! IT NEEDS TO BE CRIMPED BUT WHEN YOU OVER CRIMP YOU ARE BREAKING STRANDS OF WIRE AND DAMAGING IT.
    AFTER YOU CRIMP TERMINALS PULL ON WIRE AND MAKE SURE YOU MADE A GOOD CONNECTION.
    HEAT SHRINK ALL CONNECTORS ALSO!!
    USE EXTERNAL LOCK WASHERS UNDER ALL GROUND CONNECTIONS.(They are the washers with a seriated cuts....They cut into the metal when tightened.
  8. #48
    Rockford, IL
    THANK YOU FOR HIJACKING MY THREAD!!!!!!!!!!!!!!!!
    jk. idc its pretty much on topic anyways (not like it matters to me)
  9. #49
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by ATCharming View Post
    Sorry I thought you had plenty of responses already.....
    Just trying to help the members to get there set ups right.
  10. #50
    Rockford, IL
    Quote Originally Posted by LS2Tuner View Post
    nah dude i was jokin. feel free to do whatever u want in this thread lol
  11. #51
    Junior Member stangkiller2005's Avatar
    Bay_areA, cali
    BLACK
    00 SS
    High milage motors LOVE the bottle.........ONLY IF IT'S NOT BURNING ANY OIL!!! The looseness helps aid in the high cylinder pressure.
    ANY OIL CONSUMPTION = DETONATION!!!
    We have run straight 50w oil in very loose motors to aid in cylinder sealing and it has worked. Thats why everyone was doing early Fox bodys for the longest......They had factory forgded pistons so you could blow 250 all day and have a 10 second street car with a 150,000 miles plus on it.
    Anyways don't be scared just go to your local track and see who is really out there ALL the time with nitrous cars that are fast and not blowing anything up and you'll find out who is really a good tuner and who isn't.
    so what w oil do you recomend i use? rite now im running 15w50 moble.. i have pretty good oil pressure... with an ls6 ported oil pump..bout 40 i think it is in the middle? at idle.. and any rpms above idle it goes up... i wanna spray my car really bad.. especially cuz i hear my cam will love it.. its an ms3 on a 113lsa
  12. #52
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by stangkiller2005 View Post
    That oil should be just fine for you.
    I would say to get a good view of your cylinder condition get that thing up to running temp. and pull all the plugs rig the throttle wide open and do a compression test. As long as you don't have any weak cylinders I wouldn't think twice about blowing 150+ all day.
    Yes that 113 will take full advantage of the bottle.
  13. #53
    LS1-TA schrysler's Avatar
    utah
    1998 Trans Am Vert
    What Hp Levels Have You Seen People Use The Giggle Juice On There Stock Bottom End And Still Be A Dd?
    1998 Trans Am Vert, M6, Soon to be full of goodies......
  14. #54
    NW Chitown
    2002 WS6
    Mine is a DD and I'll soon drop in the 150HP jets. I've heard people out here spraying more than that on their DD too... haven't dyno'd it yet, but I'll suspect I'll hit something in the 400RWHP range.
    -Eagle
  15. #55
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by schrysler View Post
    If you have a good fuel system and the correct tune you can blow 175hp with NO problem I do it with customers cars ALL the time.
    And that is 175 to the tires NOT flywheel gain.
  16. #56
    utah
    1998 Trans Am Vert
    My Goal Is To Have H/c Package By Itself To Be Around 400 Rwhp And A 125 Hp Shot Of The Good Stuff. Will It Hold Up?
  17. #57
    utah
    1998 Trans Am Vert
    I Know With Blowers And Turbos The Cam Can Play A Big Difference. Is Spray The Same Way?
  18. #58
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    What all does the H/c package include.....? 400rwhp would be posiable with bottle only!! Yes it sould handle that EASY.
    Yes the bottle likes a nice wide LSA (114-112) but at the sametime we have motors that are on a 106 and blowing 175 also.
    To get the MOST benefit yes it needs that to haelp scavange all the liquid oxygen out. Is it neccesary no. Can you benefit from it yes.
    And from the all motor stand point it is going to run way better on the motor with that 108-106 cam at the sametime.......
  19. #59
    1998 Pontiac Trans Am
    When I sprayed I used the NX Wet System shooting 150; I remember the first time was like hell yea!!!!!!!!!!!!! Had about 5-6 to runs. It was for track use only. Refills were around $40 for a 10 pd bottle.
  20. #60
    HUNTER S. THOMPSON FAN Raoul-Duke's Avatar
    BURBANK
    as long as you use all the safety crap....ngk tr6 gapped plugs, wot switch, fuel pressure safety switch, window switch, good gauges (not mechanical) {fuel pump and retard timing for over a 125 shot in some cases}...you have to be retarded to blow your engine
    01 m6 z28 - lid / lt headers / 3' ory w no cats / flowmaster catback w 3' dmh e-cutout / nelson pcm tune
  1. nitrous nozzle setup cheap and various size nitrous hoses
    By RARON455 in forum Parts For Sale / Trade
    Last Post: 11-21-2011, 06:30 PM
  2. Replies: 16
    Last Post: 06-22-2008, 06:58 PM
  3. Direct Port Nitrous - Plumb Like A PRO - Nitrous Power!
    Last Post: 01-24-2008, 06:30 PM
  4. Nitrous Oxide Systems - Say Yes To No - Nitrous Power!
    Last Post: 01-05-2008, 01:00 AM
Tags for this Thread
