Results 1 to 20 of 27
    2000pontiac6
    Guest
    Question stock quarter mile times?...
    I have a 2000 Firebird and want to find out what it can do in the 1/4 mile stock. I've searched all over the web and only come up with V8 results.
    What I want to do is be able to eventually keep up my friends 2004 WRX thats supposed to do it in 14.4 stock. I know its a bit far from that but I plan on doing more mods and what to see around how close I am to start.
    SO does anyone know stock 1/4 mile times for the 2000 V6 3.8 firebird??
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    Lomita, CA
    1994 Camaro
    from what i understand (limited) of the 3.8 -- its supposed to run from a 15.8 to a 15.2 stock. depending on options installed (weight...like A/C, power stuff)...
    you are gonna have to do a couple of mods to make it run with a WRX. headers / exhaust / intake come to mind. maybe some gears or if you have a auto you can do a better torque converter... posi if you dont have it will help a little.
    Member dreaded_hope's Avatar
    Edmonton, Alberta, Canada
    97 Firebird
    What gears you have in your car greatly affect roughly about what times you'd run. Is your car auto or manual?
    1997 Firebird 3.8L
    A4,WS6 Ram Air Hood, Edelbrock Catback, SLP CAI, 85 Dry Shot
    1981 Firebird Trans Am
    http://members.cardomain.com/dreaded_hope
    2000pontiac6
    Guest
    Quote Originally Posted by dreaded_hope
    Auto.. I hope to get a stall converter over winter
    97 Firebird
    Check your door codes. If you have a GU6 option, you have 3.42's with a limited slip differential and, depending on your driving, you should be able to pull off low 15 sec times. 15.2 sounds about right. However, if you have GU4, you have open 3.08's and will run considerably slower, 15.6-15.8ish if your a good driver. If you have 3.08's like I have in my bird, I'd advise that you swap out your gears and get an LSD before you try a converter. That way you get your power to both wheels, with much better traction. However, if you have 3.42's you're set.
    2000pontiac6
    Guest
    I just looked and it has the GU6
    97 Firebird
    That means your car is equipped with the v6 performance package. That gives you a better steering ratio, dual outlet exhaust, and 3.42 gears with a limited slip. I'd say, start modding you've got a good start already.
    2000pontiac6
    Guest
    but wouldn't that mean i should have w68 appearance package too? Also... before I put on the Magnaflow I had single outlet exhaust
    97 Firebird
    Nope, the performance package is a Y87 package. The W68 package was just an appearance package. They are both seperate options. And I'm not sure why you have single outlet exhaust, perhaps the previous owner? The only way you can get those gears was with the Y87 package on the 6.
    quicky06
    Guest
    would you have to replace the entire rear end to upgrade to a lsd?
    if not where can i find what i need to do it
    97 Firebird
    Quote Originally Posted by quicky06
    Nope, you just have to get the set of gears that you want and buy a limited slip differential, like an auburn, or zexel torsion. Of course lots of people just swap out the entire rear end from a Z or TA to get disc brakes as well.
    quicky06
    Guest
    well i already have 4 whell discs so thats not a problem to me
    Plumberguy
    Guest
    Just a little insight
    I had a 98 v6 camaro and I did a lot of mods. I had an intake, cold air mod, bellow, headers, no cats, 3 inch exhaust custom, all lower control arms, strut tower brace, panhard rod. 275/45/17 all the way around, 4:10 gears with an aburn posi out of an SS, Electronic spark booster and 75 shot of Nos. With all of this I was able to keep up with Stock Z28's. There is fun to be had with a 6 but you will always want to go faster after you get a taste. And all that means is V8.
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    I have an LS1 look on my Camaro, but I'm planning on doing suspension mods and saving the rest of the performance cash on LS1. I do know of a few FAST 3800's though. I know of one hitting like 10's. I can hardly believe it!
    quicky06
    Guest
    Quote Originally Posted by 7camaro7
    but they probly have 1 seat no radio an a completly rebuilt engine
    Nashville, TN
    02SS6spd VERT!
    I believe he has at least 2 seats and definitely a rebuilt engine with turbo and all, don't remember about radio and ac
    97 Firebird
    10's? I've heard of 3.8 fbodies in the 11's, not in the 10's though, that's impressive! Wow.
    Nashville, TN
    02SS6spd VERT!
    my bad, I think he's still in the 11's... just looked again, his goal is 10.99sec but he does have >456rhp
    I swear it's just a v6!
    Jul 2001
    Westwood, NJ
    1997 Firebird V6
    That would be viper.... he has the rwhp and rwtq... and his combo is very impressive... but no good times!
    See sig
    Look into LSD and a converter.
    That will really wake the car up.... then little things such as intake/ exhaust
    nitrous et & mph: 12.168 spinning, 110.95 mph
    n/a et & mph: 13.746, 96.38 mph
    Best 60 ft w/ et streets 1.584 spinning!
    check me out at www.bbbracing.com
    Beater - 2006 Mercedes E350 A7
  1. quarter mile times?
    By 1999sscamaro in forum Camaro / SS
    Last Post: 07-15-2010, 07:11 PM
  2. Anyone know stock quarter mile times?
    By speedracer25f in forum Firebird / WS6
    Last Post: 07-29-2008, 10:04 PM
  3. Wanting better quarter mile times
    By silverz28camaro in forum External Engine
    Last Post: 10-31-2006, 08:07 PM
  4. quarter mile times for 1500 5.3 anyone??
    By vorteclover350 in forum GM Trucks
    Last Post: 01-24-2006, 12:49 PM
  5. stock quarter mile times?...
    By 2000pontiac6 in forum V6
    Last Post: 11-07-2005, 10:26 AM
