Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 106
  1. #61
    Tulsa,OK
    Quick Silver
    2002 Z06
    Once the passenger kit is installed then both motors are on their own isolated circuits.
    The Driver side should be fine. There is a small voltage drop caused by the factory express down module so the only way to remedy that is to use the DriverSide express down kit.
    You could install the passenger kit on the driver side but you would have to remove the factory express down module and you would lose your express down obviously.
  2. #62
    south, GA
    00 Formula Firehawk
    sounds interesting. I may have to give this a try. Will it wear out the motor faster than usual?
    Thanks
  3. #63
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by Stephen Griner View Post
    Thanks
    This is for the purpose of INCREASING the life of the motor.
    It's the drop in voltage that burns out the motor.
  4. #64
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    im gunna get one this week!
  5. #65
    south, GA
    00 Formula Firehawk
    Quote Originally Posted by rbob93 View Post
    Very cool. I will have to get one of these. It seems that the driver side motor goes out faster though.
  6. #66
    Tulsa,OK
    Quick Silver
    2002 Z06
    Yeah the factory express down module seem shit or miss on how much of a voltage drop it causes. Generally people use the Driver side ALLOT more though.
  7. #67
    Greenville, NC
    2000 Pontiac Trans Am
    Angry Rip off
    Worked fine for about 2 months, then went haywire & made the motor lock up. Window wouldnt roll up until I cut the "passenger window fix kit" out & then everything was fine. Window rolled up slower without the kit, but actually worked. The whole purpose behind the kit is to prevent you from having to replace the window motor so many times, but it's not worth the trouble to splice & run all the wires & try to cram that nest of wires and HUGE relays into your door panel. Not worth it, just complain to GM & replace your window motors.
  8. #68
    Tulsa,OK
    Quick Silver
    2002 Z06
    Quote Originally Posted by rlc0816 View Post
    This is VERY basic electronics, nothing about putting relays in between your motor and a switch will make things go haywire unless you had bad connections or put the relays inside the door and they got wet.
    Putting two relays with dongles inside the arm rest is not that hard either. Hundreds of people have done it over and over.
    Sorry you had such a bad experience.
  9. #69
    doylestown, Pa
    SILVER
    2004 CTS-V
    No, this is not a rip off. You screwed it up somehow.
  10. #70
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Won't stop me from buying it when I get time and money. Only reason I haven't bought it yet is because I know I won't have the time to do it right now, and I tend to lose stuff when I put it "away"....I seem to forget where "away" is Plus you guys are like, an hour from my house. I'll just come pick it up one day, and install it the same day (that day will just so happen to be when my electrical engineer brother-in-law is up from Texas )
    This guy is the first complaint I've heard
  11. #71
    Sponsor autotrix's Avatar
    Tulsa, OK
    Sounds good let us know! Thanks for all of the support people!
  12. #72
    Tulsa, OK
    bump
  13. #73
    Tulsa, OK
    Black Friday Bump
    Got passenger window problems?
    http://www.autotrix.net
    **Window Express Down Modules now availible**
    http://www.autotrix.net/products.html
  14. #74
    Aug 2009
    NC
    midnight blue
    2000 trans am
    I will have to buy one when I get back and try it out, I remember when I was younger when I had my 97 firebird I had so many problems with my window motors it was insane. I will give it a shot on the trans am so hopefully I wont ever have to replace the motor or atleast for a while.
  15. #75
    Tulsa, OK
    Thanks alot! I hope for your safe return to the States.
  16. #76
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    So my passenger side window rolls down but it wont roll back up in one shot, itll roll up some slowly and stop if i wait a while and try again itll roll up a bit more and stop. If i install this kit will it fix the problem or do i forsure have to go get another motor and then install the kit?
  17. #77
    Tulsa, OK
    The kit has been known to wake up old motors and keep them alive for longer but sometimes you just have to replace the motor. We do sell a package deal with window motors. You can choose to add one or two motors; they are dorman window lift motors.
    I suggest to install a kit and see how well or long it allows the mototr to last. When you have to replace the motor you will already have the kit in place to allow for a longer life for the new one.
  18. #78
    Junior Member bbadassta96's Avatar
    Aug 2009
    Brighton, IL
    1996 Trans am
    ya i put it on my 02 ss and love it. The window goes down twice as fast as before. bump the pass window upgrade.
  19. #79
    Member joedude02's Avatar
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    do you have anymore pics of that red T/A?
  20. #80
    Tulsa, OK
    Quote Originally Posted by bbadassta96 View Post
    Thanks for the support!
    Quote Originally Posted by joedude02 View Post
  1. autotrix passenger window fix
    By WS6S in forum Parts Review
    Last Post: 03-02-2016, 12:40 PM
  2. Passenger side window
    By SS Camaro UK in forum General Help
    Last Post: 01-15-2013, 06:54 AM
  3. Passenger Window won't work
    By kempfer99ta in forum Firebird / WS6
    Last Post: 10-02-2009, 01:54 PM
  4. passenger side power window motor
    By bcphilly01z28 in forum General Help
    Last Post: 05-31-2007, 06:21 PM
  5. Passenger Window Motor
    By mitch98ss in forum Parts Wanted / Trade
    Last Post: 09-19-2006, 06:53 PM
