Results 1 to 11 of 11
    old timer blue02Z's Avatar
    2002 Z28
    header install question about tools
    Hey people, whats up? I'll be installing LTs on my car pretty soon and I was just wondering if there was any tool that was a neccessity to have. I have a lot of damn tools and I'm going to try to talk my boss into letting me use the shop where i work with a lift. (I work at a dealership) so hopefully I wont be laying on my back. But like i said, is there any special tool out there that will be needed? thanks for ya'lls help
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    nope. pretty straight foward.
    Aug 2006
    Missouri
    94 Camaro Z28
    I used a cherry picker to lift the motor on the passenger side so the header would fit. But nope, no special tools, just hand tools.
    2002 Z28
    thanks everbody, hopefully it'll go pretty smooth
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    a 1inch wobbley for the last bolt on the pass side, thats what i've heard
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Regular hand tools, possibly an impact.
    2002 Sunset Orange TransAm 6 spd.
    http://www.mustangmods.com/data/1327/dadsigpic2.jpg
    Aug 2006
    Missouri
    94 Camaro Z28
    I wouldn't use air tool on the header bolts though. Don't want to torque 'em too tight or break one off in the head. Then it becomes a very expensive project. But a good reason to get those heads ported.
    Bragg NC
    Met. Sunset Orange
    01 SS
    A Ten milimeter rachet wrench will become your best friend. lol too remove the old bolts. A universal would make it easier also but not needed. just simple hand tools.
    If you cant use a lift make sure you have a way of gettin your car a few feet off the ground.
    J
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by sunsetorangess View Post
    J
    Agreed, getting the car high enough safely can be more of a problem than it sounds.
    Likes twisty roads bene's Avatar
    England but from TX
    Light Pewter Metallic
    2K Camaro Z28
    GL and take your time.
    2002 Z28
    thanks guys
  1. Header Install Question
    By miller456 in forum External Engine
    Last Post: 11-20-2007, 08:29 PM
  2. header install question
    By biga0206 in forum External Engine
    Last Post: 08-02-2007, 07:48 AM
  3. Header Install Question - Motor Oil Dip Stick
    By MISSMYZ in forum External Engine
    Last Post: 02-15-2007, 06:14 PM
  4. header install question?
    By sb001 in forum External Engine
    Last Post: 04-11-2006, 03:17 PM
  5. header install question
    By tals199 in forum External Engine
    Last Post: 11-09-2005, 05:39 PM
