05-28-2006, 04:46 PM #1
Can't find a floor jack that works for my car
I'm trying to find a good floor jack for my 02 Z28. I've always used bottle jack for my trucks but this is the first car I've had so I got to get one. The first one I got (Westward 2 1/2 ton)was a piece of crap and got stuck on the way down and I almost killed myself getting it to come down. Then I got a slick craftsman aluminum racing jack but the handle always aims up at a slight angle and won't clear the body work when trying to lift the car from right under the engine cradle. Before I spend any more $$$ I want to know what brand and model of floor jack YOU HAVE OR KNOW WORKS WELL ON THIS CAR (02 Z28 Camaro). Please be as specific as possible and model # would be very helpful along with where you purchased it and price. Thankyou!
05-28-2006, 06:35 PM #2
- Thornton, CO
Before I was lowered my 2 ton jack from Checker Auto worked great.
Now I need ramps.
05-28-2006, 06:51 PM #3
- Sep 2005
- Pueblo, Colorado
Black- 1998 Pontiac Trans Am
I use the steel jack from craftsman. Its been working great for 2 years now. Before I jack the car up, I just drive up two pieces of wood (2x4). it gives me the clearance I need to use the jack. Regardless of the jack I'm using.
05-29-2006, 05:47 AM #4
- Virginia
Advance Auto has a good 2 ton called Speed Lift model F-777. I've used it on chevelles, gto's, and 2003 eclipse that has been lowered 1 1/2".
05-29-2006, 07:04 PM #5
I got a Craftsman 3.5 ton one pump to load height with 2 heavy duty jackstands for like $60 on sale a couple years ago. This sucker is very heavy duty and could be used in a commercial shop. It weighs like 85 pounds by itself so it'll be quite a bit different from the aluminum one-haha. You have to remove the saddle to get it to slip under the front crossmember (I'm at stock ride height), and slide it under the front from the side under the foglights. Then it takes a few small pumps before the car raises up enough to get a long stroke with the handle and get things moving fast, but hey it's all good, any jack is like that. I guess the main advantage is the handle goes all the way down flat to get under the front end. Didn't know that about the aluminum one not going down flat with the handle-always like the looks of that jack but would have been dissappointed with the handle issue. An added advantage is the 85 pounds makes for a good trunk weight in the snow storms, makes the Camaro into a snow patroller. (no I don't haul it around the rest of the time-hehe)
05-30-2006, 09:51 AM #6
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
It is a real PITA to jack my Z from the front or the rear. Damn low ass air dam in front gives you about 2" jack handle clearance, the engine cradle is designed where jacking it up from there can be tricky if you don't have it centered correctly, you usually have to drive one wheel on a brick or something just to get the DAMN jack under it.
05-30-2006, 10:27 AM #7
- Aug 1999
- Arizona
I use two of the Craftsman Aluminum jacks. And my car is lowered.
05-30-2006, 05:18 PM #8
Thanks for the replies, does anybody have a good made in U.S.A jack, I hate buying all the made in china crap, I tried another craftsman 3 ton steel jack but the effort to lift the car was ridiculous, I was almost jumping on the damn handle and this thing is supposed to be able to lift 6000 lbs
Also where are you guys putting the jacks stands in the front and rear after lifting up the car? I was going to put them in the unibody notches for the spare tire jack but the car is at such and extreme angle once lifted the car will barely touch the flat part of the jack stand.
05-30-2006, 06:05 PM #9
- Mar 2006
- Tennessee
black- 1999 Pontiac Trans Am
A word of caution.
If you jack or support your car at extreme angles and twist the chassis, you risk breaking or cracking your hatch glass or your t-tops. I had tires put on, and the shop foreman had me loosen the t-tops, and crack open the rear hatch.
Seems he had seen something break before.
Only takes a second to loosen that stuff up. Better be safe.
If you need to get the car in the air and it can rest on the tires, get a set of Rhino Ramps. I have had a set for years, and they are well worth the money. They are cheaper now than when I bought mine many years ago. The shallow ramp angle will clear the nose of a TA and I imagine just about anything else. I dont even think of trying to get under the car without the ramps.
I use a small cheap hydraulic floor jack when I rotate my tires by jacking under the A-arm where the shock mounts, one side at a time. I jack it just enough to clear the tire off of the ground. I use a 2 ton large floor jack under the differential, again just barely lifting the tires off of the ground.
I have found that most jack stands are just too tall for f-bodies. You have to get the car too high to use them, in my opinion.
05-31-2006, 06:25 AM #10
Thanks thirdbird for that info, I didn't know you could crack the glass , that would ruin my day LOL. I'm gonna get those ramps too. Your right about the jack stands, most stand anywhere from 11"-12" and thats ridiculous. Now I just need a good made in USA jack.
05-31-2006, 06:31 AM #11
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
A couple of boards and slide in on the left or right of the air dam. Any jack works when you do it like that.
05-31-2006, 10:07 AM #12
- Dec 2005
Pewter- '99 Z28 M6
Originally Posted by BIG D's SS
What's a good floor jack?
By MasonWS6 in forum ToolsReplies: 5Last Post: 11-16-2014, 07:27 AM -
Question: Floor jack recommendations
By [CJ] in forum ToolsReplies: 37Last Post: 03-29-2011, 10:48 AM -
Good jack/jack stands for Camaro Owners
By mammoth713 in forum Camaro / SSReplies: 10Last Post: 04-01-2010, 03:01 PM -
Favorite/best floor jack
By preston1980 in forum ToolsReplies: 7Last Post: 03-21-2010, 09:12 PM -
Floor Jack
By thearborbarber in forum ToolsReplies: 13Last Post: 07-09-2008, 04:50 PM
