Thread: broken push rod
05-05-2006, 12:12 PM #1
broken push rod
i have had someone take off my valve cover he says i sucked in a push rod .what does this mean i broke one is it a big deal and do i have to take out the engine to fix it he said the block may be damaged could this be so??
05-06-2006, 05:13 AM #2
where did the pushrod go? have you went to see this for yourself? the LS1 motors have a lifter cup. the pushrod can't really go anywhere except in the lifter area. it can bend and fall over, but not get 'sucked in'. if this did happen, the heads will have to come off. here's a pic of the lifter cups where the pushrod would have disappeared to.
05-06-2006, 12:24 PM #3
ok he says the lifter is jammed in the bore adn if you takes it out the bore will be damaged so basically the block will be so should i buy a new block and use all my stuff or buy a vetter engine and put my componets in it like cam,heads,intake,trans&rear
05-06-2006, 12:29 PM #4
they make lifter bore sleeve repair kits for most engines. look to see if they have one for the LS1 motors. it will require removal of the motor to complete this repair. i'm wondering how the lifter got stuck in the bore to begin with. what happened to this motor to cause it to go to the repair shop? you could just get another shortblock and put your stuff on it. hell, get a stroker at this point.
05-06-2006, 12:46 PM #5
did a burnout and reved it too high and heard a pop.I bought the car with alot of horsepower not really knowing anything about engines i dont think it had a rev limiter. so what do you think i could do how much does a block cost that i can put all my stuff on and will bolt right up??
05-09-2006, 07:10 PM #6Originally Posted by jbigdawg79
push rods are in, now what?
By freddy_caprice in forum Internal EngineReplies: 2Last Post: 07-17-2011, 02:24 PM -
Push Rod Length
By meathammer in forum Internal EngineReplies: 7Last Post: 03-25-2011, 03:56 PM -
Help Push Rods
By ls1transam312 in forum General HelpReplies: 6Last Post: 02-11-2010, 02:55 PM -
push rod
By ban-one in forum Camaro / SSReplies: 3Last Post: 12-18-2006, 03:51 PM -
lost push rod
By jbigdawg79 in forum Internal EngineReplies: 1Last Post: 05-06-2006, 05:18 AM
