Results 1 to 3 of 3
Thread: Used engine, been sitting
12-03-2023, 07:40 AM #1
- Dec 2023
- Indiana
Black- 2003 Silverado
I recently got a 2003 6.0 lq4, past owner says it has sat since 2011, has wiring harness and drive by wire, and computer. Have .not checked to see if it turns freely, thinking I should spray some WD40 before turning the crank. If it turns freely, gonna replace seals and gaskets, etc. Are my plans good... is there a better way to get the parts rotating before starting the engine?
12-04-2023, 03:09 AM #2
was it covered (sealed) or left outside exposed? it really makes a difference. may want to run a bore scope thru plug holes see if any rust in cylinders before you spray wd40 and turn over. if there's rust, a mixture of cheap regular trans fluid (non synthetic) and diesel, let sit for 24-48 hrs in cylinder. of course change oil after
00 FB Vert - Stock
12-04-2023, 12:04 PM #3
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I agree with SMWS6TA, borescope first, then soak the cylinders, when you do turn the crank (after draining the fluid out of the cylinders of course), do it without the plugs in it.
If it's been sitting for over a decade, I wouldn't be surprised if it needs a slight honing of the cylinder bores, which means new pistons; probably a good idea to get new pistons, especially ones that increase the compression ratio, as I believe the compression ratio of a LQ4 was below 10:1SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
sitting uneven?
By mr_r0bert0 in forum Camaro / SSReplies: 12Last Post: 08-26-2009, 02:47 PM -
Sitting on my Couch...
By Y2KSS1363 in forum Almost Anything GoesReplies: 3Last Post: 05-18-2009, 09:01 AM -
imagine sitting shotgun
By stangslayer98 in forum Almost Anything GoesReplies: 2Last Post: 07-15-2008, 09:28 PM -
So we were sitting at the dinner table....
By Sarge in forum Almost Anything GoesReplies: 43Last Post: 01-28-2008, 11:29 AM -
Baby sitting
By clarkjw24 in forum Member's RidesReplies: 7Last Post: 09-21-2007, 07:35 PM
