Thread: Gen Iv crank in a gen III block
11-21-2023, 12:24 PM #1
- Nov 2019
- Irvine, California
I have a ls block without AFM already bored 30 over with new pistons. Also have a truck cam and lifters i want to use. Can i use my 58X crank in a gen III Block without the AFM if I disable it with a tune ?
And use my timing cover with the cam sensor on the gen III block ?
11-28-2023, 07:02 AM #2
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Did the vehicle that the engine is going in, originally have AFM?
None of the equipment that you are mentioning enables AFM, so I am a bit confused.SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
11-29-2023, 05:20 AM #3
- Nov 2019
11-30-2023, 05:39 AM #4
Question: IV Gen drivetrain in III Gen truck
By Z28dryva in forum LSx Retrofit and SwapReplies: 9Last Post: 02-11-2013, 06:55 PM -
Gen III or IV engine or wait for Gen V???
By Whamhammer in forum Internal EngineReplies: 24Last Post: 08-29-2012, 11:03 AM -
594HP 5.3L Gen III Small Block for $3,252 - 594 Horsepower F
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-21-2011, 09:52 AM -
Gen III to Gen IV swap
By 02transamce in forum General HelpReplies: 0Last Post: 06-19-2011, 09:05 PM -
By Ed Blown Vert in forum Almost Anything GoesReplies: 4Last Post: 03-12-2011, 06:06 AM
