Results 1 to 3 of 3
Thread: Question on Temperature issue
11-15-2023, 07:41 AM #1
- Jul 2023
- Texas Round Rock
black- 2002 trans am
I have 2002 trans am rebuilt LS1
Ever since before we rebuilt it and bought it used it had a flickering oil pressure sensor.
So engine was rebuilt now after it hit 220 and random times the temperture will drop by 100 degree.
I have replaced sensor twice and today air bleed anti- freeze by raising front end and radiator cap off.
Did get some air out.
Now while car was idling I would slightly pull on temperature sensor and car died.
Was able to restart each time no problem.
So the question do you think it is the alternator wiring causing all this issue?
Is the oil pressure reading through same harness??
Can this cause the weird temp drop on coolant?
Current waiting for temp on car to drop to check out
Thanks for any ideas
11-16-2023, 08:03 AM #2
I would check harness, look for broken or burnt wires, following that get a new temp sensor and replace see if it continues.
.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
12-14-2023, 06:48 AM #3
- Jul 2023
- Texas Round Rock
So we order a replacement connector and wires that came from GM. I spliced solder in and this has fixed the issue.
Help: Temperature Question
By fred007 in forum General HelpReplies: 9Last Post: 07-18-2012, 03:29 AM -
Temperature Issue 2002 Trans Am WS6
By Zedtwentyeight in forum Firebird / WS6Replies: 4Last Post: 11-07-2011, 06:41 PM -
By Zedtwentyeight in forum General HelpReplies: 12Last Post: 11-07-2011, 05:58 AM -
Bringing up an old question/issue
By Whiteboycntdnce in forum NitrousReplies: 4Last Post: 09-25-2007, 09:51 PM -
update on engine operating temperature issue
By Raise in forum Internal EngineReplies: 11Last Post: 09-26-2005, 10:13 AM
