Results 1 to 3 of 3
    Jul 2020
    TX
    Picture: LS3 Harmonic Balancer Separating?
    This is a new LS3 crate motor that I bought 5 years ago and just got installed and running in spring ?23. Im using the CTSV accessory drive. A belt chirp got my attention and it looks like the harmonic balancer is out of alignment causing the belt on the balancer to move back toward the block by 1 or 2 ribs. The crank bolt is tight so I started looking at the balancer itself? see the picture: has the outer ring started to move toward the radiator? This balancer doesn?t have a recess/step lime the truck/SUV/11-15 Camaro version and should be flush on the front according the chart. I barely have a few hours on the motor so none of it makes sense. Appreciate your help? Thank you!
    Sent from my iPhone using Tapatalk
    Jul 2020
    TX
    Found a picture of the motor from a few years ago.
    Jul 2020
    TX
    FYI, I replaced the balancer and it was definitely separating. Pulley?s and belt are aligned now.
  1. Question: Harmonic Balancer
    By joker in forum General Help
    Last Post: 09-29-2011, 09:55 AM
  2. Harmonic Balancer
    By Camaro69Mac in forum General Help
    Last Post: 05-20-2010, 01:42 PM
  3. Harmonic Balancer
    By TwistedSS in forum External Engine
    Last Post: 05-16-2006, 07:30 AM
  4. harmonic balancer
    By Mr. CarelessAndImprudent in forum External Engine
    Last Post: 11-06-2005, 08:22 AM
  5. harmonic balancer
    By Mr. CarelessAndImprudent in forum Almost Anything Goes
    Last Post: 11-03-2005, 09:38 PM
