Good Day all,
I am having an issue with my 1998 WS6 dash a/c vents being stuck blowing very light out of the center panel of the dash towards the windshield.
Just had the A/C repaired and it's cold but NOT blowing from the dash vents. Without dash vents the a/c is pretty useless in this heat.
I DO remember last year finding a group of small hoses (i'm guessing vac hoses) with a broken stem from a 3 or maybe 4 way splitter.
My simple mind can not relocate the line nest. I thought it was toward the rear of the eng. Maybe in the housing above with the wiper motors etc??
Tech that worked on the a/c tells me it needs the "door actuator" replaced that changes the airflow from top to dash vents to floor.
I don't think they are having much luck finding that part but I'm curious if the issue is simply the broken splitter for the vac lines???
Anyone here had this issue and if so what was the path to correction?
Any / all help is much appreciated.
Thanks.
