Results 1 to 11 of 11
Thread: How's everyone doing?
06-21-2023, 07:24 AM #1
- Oct 2021
- usa
white- 1999 firebird
Have not posted in a while, just checking in on this great board, to see how everyone is doing.
06-21-2023, 11:26 AM #2
08-05-2023, 12:58 AM #3
08-07-2023, 05:14 AM #4
I finally purchased my mid life crisis project car....
00 FB Vert - Stock
08-07-2023, 11:33 AM #5
08-09-2023, 03:45 PM #6
Turned 52 in Jul.
Bought a 78, still trying to confirm the Vin and Cowl tag but I believe it was a Formula that came with a 400.
It's a fixer upper and no drive train but not too bad. Left qtr panel needs replaced as well as some floor pans. Rear window ledge, too, but not worried about the work.
Drive train plans are unless a 455 drops in my lap I'll go LS swap. Now which LS depends. My only stipulation from the wife is it has to be an auto and not modded out that she can't drive it. My 98 is too much for her to handle
08-12-2023, 12:28 AM #7
08-21-2023, 08:08 AM #8
08-21-2023, 08:13 AM #9
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I am in the beginning steps of working to "restore" the interior of the WS6.
Looking to replace the dash top, put in new carpet, seat leather, and fix the seat foam. Going to sound deaden the floor as well.
This winter, I will need to instrument panel out, to fix the gauge needles bouncing around.SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
08-21-2023, 03:21 PM #10
Look at Fat Mat sound deadner. Works great for heat as well. Did my 98 and will be doing the 78 too in it as well.
08-22-2023, 04:55 AM #11
