05-08-2023, 11:22 PM #1
- May 2023
- United States
White- BMW
Does a 17-inches Wheel Make More Noise?
Wheels don't cause road noise. It's the tire size that causes it. However, when selecting new tires, they should have energy efficiency ratings. The higher it is, the lower the rolling resistance, thus less noise and harder wearing.
However, the noise levels 17 inch alloy rims aren't that dramatic, and unless you trialed them back to back, you'd probably be hard-pushed to notice a difference. In some cases, you may even find the 16″ tire is louder than the 17″ tire because the model also plays a huge role.
05-09-2023, 11:55 AM #2
wheel size has nothing to do with road noise. the noise you hear is from tire material, it's tread and road surface.
00 FB Vert - Stock
05-24-2023, 06:28 AM #3
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
09-18-2023, 09:40 PM #4
- Dec 2017
- Hinesville, GA
We changed the wide and worn-out tires with narrower dura grappler nitto tires on the same wheels. The ride has been quiet.
Do drilled/sloted rotors make noise?
By JayTA98 in forum General HelpReplies: 15Last Post: 05-14-2010, 03:51 AM -
Help: clicking noise coming from wheel, or?
By trixysrace11 in forum Firebird / WS6Replies: 9Last Post: 07-13-2009, 09:11 PM -
noise from front right wheel
By 1MileCrash in forum General HelpReplies: 10Last Post: 08-07-2008, 02:38 PM -
Do Richmonds make more noise?
By rerunss in forum DrivetrainReplies: 2Last Post: 09-08-2006, 11:36 AM
