Hello everybody
Just did some more upgrades on my 2002 Camaro Z28 and having issues with tune. The car was tuned when the cam was installed but turner locked the PCM and it needs to have a base tune loaded to be able to make it to new tuner which is like an hour and a half away. Can someone look over my hp tuners file and let me know what needs to be adjusted to make car drivable. The machinic is having issues loading up a base tune with the below setup. Attached is my hp tuners file and log. Thanks in advance
255LPH racetronix fuel pump with harness
48 lb bosch injectors - came with data for HP tuners
92mm fast intake
92 nick willams tb
85 z06 MAF
TSP ls6 stage 2.5 ported heads 58cc with 660 dual springs kit
1.7 ratio Howard cams roller rockers
TSP 228r6 @112
