Results 1 to 1 of 1
12-24-2022, 01:18 PM #1
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Anyone make good/better OEM spring rate & ride height spring
At 221K, I am getting what feels like suspension "bouncing" or oscillation, pretty sure the springs have had better days. Shocks have been replaced multiple times, front springs were replaced about 80k ago with someones take-offs from when their SS was newish. People think the car looks lowered too. I do scrape the ground a little with speed bumps and change of grades on my driveway.
I want to stick with a stock ride height, and closortable ride. to stock spring rates (maybe a smidge more handling minded), so I can drive it more frequently and not scrape bottom and/or want a fairly comfortable ride. I shouldnt need to do anything radical with the suspension as its all tubular, and have subframe connectors, with sticky, wider than normal tires. (See build in signature)
Anyone have any educated suggestions?
How To Pick The Right Spring Rate - Rated A For Fu
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 12-10-2009, 09:40 AM -
Question: Spring Height- HELP
By coprod in forum Suspension and HandlingReplies: 0Last Post: 04-15-2009, 03:51 PM -
Spring Rate Changes
By fxgs in forum Suspension and HandlingReplies: 1Last Post: 03-08-2009, 06:54 PM -
Spring rate questions...
By Mr. Luos in forum Suspension and HandlingReplies: 10Last Post: 09-11-2007, 01:05 PM -
Does anyone make stock a height performance spring?
By Zapper2003 in forum Suspension and HandlingReplies: 7Last Post: 04-19-2007, 11:13 AM
