Results 1 to 2 of 2
Thread: Uneven rear ride height
11-23-2022, 02:48 PM #1
I recently upgraded the suspension in my 2000 TA with BMR lowering springs, control arm relocation brackets, control arms, panhard rod, sway bars and torque arm. The car sits 2” lowered on the passenger rear regardless of what I do. I called BMR and on their recommendation, I loosened all the bolts with poly bushings and then greased and torqued it all with load with the same results. I’ve since removed the rear springs and shocks and replaced them with QA1 coilovers. I moved the spring perch on the passenger side 2-3 inches higher than the drivers side and it hasn’t helped at all. Drivers side sits 27.25” and passenger side is at 25.25”. Any help is appreciated. Car has never been hit and is a super clean 12k mile TA
11-30-2022, 07:23 AM #2
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Could the relocation brackets been bent, or installed incorrectly? Are the rear control arms bent or (if adjustable) adjusted incorrectly?
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
1995 camaro ride height
By 1MileCrash in forum LT1Replies: 4Last Post: 05-08-2017, 07:04 PM -
What is normal ride height???
By Whamhammer in forum Suspension and HandlingReplies: 2Last Post: 05-21-2016, 02:25 PM -
Ride height question
By Dr.Crash in forum Suspension and HandlingReplies: 3Last Post: 06-29-2008, 12:18 AM -
ride height?
By Dr.Crash in forum Suspension and HandlingReplies: 8Last Post: 09-11-2007, 11:02 AM -
Stock ride height?
By UKXK189 in forum Suspension and HandlingReplies: 1Last Post: 07-26-2007, 01:14 PM
