Results 1 to 3 of 3
    Junior Member fws98ws6tt's Avatar
    Jul 2009
    Albertville, Alabama, United S
    1998 ws6 trans-am
    Question on 10 bolt ?
    I have a 98 ws6 with stock rear sub frame connectors, that we're welded on question is I have a big bump that sounds like someone hit the under side of body one time only when I turn left! Not right and has no wheel hop unless you really get on it and anyone hear of this or had it happen or know what it is?
    98 T/A w/ mods, 00 FBVert
    Could be several things.
    Shock , bump stop, bushings.
    00 FB Vert - Stock
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Check the rear sway bar as well; I had a sway bar link break before and sounded like as you described.
    SLP Air Lid/Smooth Bellows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @:
    415 rwhp
  1. 10 bolt question
    By 2-bowties&abird in forum Drivetrain
    Last Post: 03-02-2008, 07:21 PM
  2. 12 bolt question
    By 99Ls1fever in forum Drivetrain
    Last Post: 11-07-2007, 02:50 AM
  3. 10 bolt question
    By ZForce1 in forum Drivetrain
    Last Post: 11-03-2007, 03:38 PM
  4. Gm 12 bolt question??
    By sscrazy in forum Drivetrain
    Last Post: 08-15-2006, 09:50 AM
  5. 12-bolt question
    By Ric in forum Drivetrain
    Last Post: 09-21-2005, 08:06 PM
Tags for this Thread
