Thread: What's in my Engine Coolant?
05-12-2022, 09:00 AM #1
- May 2010
- Fort Mill, SC
Black- 2000 Camaro SS M6
My car is a stock 40K mile 2000 Camaro SS that I have owned since new. I have changed the coolant many times since new but i now have this weird issue that is head scratcher for me. Before I changed my coolant last week, I noticed small pieces of what appeared to be foam floating in the coolant. It also feels like foam in your fingers. A picture of this stuff is shown below.
As such I made sure to thoroughly flush the radiator, engine block, and overflow bottle several times before I changed the coolant. Just the same the new coolant still has this stuff floating around. Are there any gaskets that the coolant touches anywhere in the system that are made of foam? I can't imagine there are but I also don't understand where this stuff could be coming from.
01-14-2023, 09:25 AM #2
Engine coolant is an antifreeze solution made up of a mixture of water and antifreeze chemicals such as ethylene glycol, propylene glycol, and other additives to protect the engine from freezing and overheating. It also helps keep your engine clean and free of rust and corrosion. Other ingredients may include corrosion inhibitors, foaming agents, dyes, surfactants, and lubricants.
01-29-2023, 06:28 PM #3
- Dec 2017
- Hinesville, GA
There is nothing that seems to worry here.
01-30-2023, 05:26 AM #4
Only remote possibility I can think of that there might be a seal is from the water pump, t-stat or some how the heater core has begun to deteriorate. Check your passenger floor board notice any dampness or a coolant smell when the heater is on?
00 FB Vert - Stock
02-03-2023, 12:01 AM #5
- Feb 2023
- Bogota, Colombia
Exterior Color- 2018 X2
Thanks a lot for sharing this topic here. I would like to know more about it.
05-19-2023, 01:57 AM #6
- May 2023
- 7 Elaine Ct Cohoes, New York
WS6- 1998
12-14-2023, 10:08 PM #7
- Sep 2023
- USA
blue- 2020 Honda
I would like to know more about it.Thank you for sharing it. Drift Boss
Engine Coolant
By pajeff02 in forum Drag RacingReplies: 16Last Post: 05-15-2011, 09:28 AM -
Help: engine coolant sensor!!!
By pmolina0436 in forum GTOReplies: 43Last Post: 01-05-2011, 06:22 PM -
Engine coolant issue with my LS1
By myk02k in forum Internal EngineReplies: 25Last Post: 11-15-2007, 03:42 PM -
Dex Cool engine coolant??????????
By LETHALxLS1 in forum General HelpReplies: 43Last Post: 02-23-2007, 07:20 AM -
FYI: Engine Coolant In 99 SS Vert
By 2tall in forum Internal EngineReplies: 0Last Post: 04-11-2006, 09:00 AM
