Results 1 to 2 of 2
Thread: ACL Bearings, Any Issues,
08-17-2021, 12:36 AM #1
- Apr 2011
- las vegas
Blue- 2005 sandrail
I am doing a LS2 build with a ACL Race bearing, one machine shop uses them and another says they flake,
anyone use ACL Main bearings lately, I have always used Clevite in the past,
Also confused about design, the normal Clevite has the groove on the bottom bearing about 80% the ACL is grooved 100% of the bottom bearings,
Dart recommends a bearings that has a 100% of the groove, Clevite does make a special LS bearing for Dart that is 100% grooved,
Will More groove add more Rod bearing oil, and Less Crank oil?
08-17-2021, 05:36 PM #2
I have King bearings in mine. no issues.
00 FB Vert - Stock
Help: Atk 408 ate my rod bearings
By Wattzy3 in forum General HelpReplies: 0Last Post: 09-18-2016, 04:19 PM -
Cam Bearings
By jetaws6 in forum Internal EngineReplies: 21Last Post: 08-10-2010, 04:21 AM -
Cam bearings
By Z28_Driver in forum Classic MuscleReplies: 4Last Post: 11-26-2009, 02:16 PM -
Cam Bearings
By slacker4321 in forum Internal EngineReplies: 1Last Post: 01-14-2009, 11:25 AM -
ls1 bearings
By wesmc in forum Internal EngineReplies: 4Last Post: 04-04-2008, 12:12 PM
