Results 1 to 16 of 16
Thread: Lifters
05-13-2021, 10:13 PM #1
- May 2021
- Brisbane QLD Australia
Lifters
So im in the process of a mild ls1 build. Will be running decent cam (236*-240*-111*-.631"-.610"), ls6 intake, bigger throttle body, new pushrods, ported 241 heads and set pf Howards 1.7 Billet roller rockers. Aiming for around 400+ rwhp.
Main question i have is surrounding lifters. Looking for quality aftermarket and was wondering if i really really need tie/link bar lifters considering its not a mega hp motor? To me lifters are cheap insurance, so I don't want to really risk standard or ls7 ones, but I am not sure if i should just go quality single or tie bar lifters.
Any help would be appreciated.
Cheers
Lee
05-17-2021, 08:25 AM #2
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
You'll be fine with a quality single lifter. I have been using the Johnson lifters, little more money than the LS7 but way better quality.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
05-17-2021, 04:11 PM #3
- May 2021
05-17-2021, 05:21 PM #4
- May 2021
05-19-2021, 08:22 PM #5
I'm running LS7's still in my 403.
00 FB Vert - Stock
05-19-2021, 09:46 PM #6
- May 2021
05-19-2021, 09:46 PM #7
- May 2021
05-20-2021, 06:37 AM #8
- May 2010
- Wilkes-Barre, PA
Johnson Lifters part# 2110R
05-20-2021, 06:51 AM #9
- May 2021
06-28-2021, 03:46 AM #10
- Oct 2020
- Tampa, FL
"Johnson Lifters part# 2110R"
09-06-2021, 09:13 AM #11
Thank u!
employee time tracking
09-06-2021, 04:28 PM #12
- Jan 2021
- California
09-16-2021, 06:30 AM #13
- Oct 2020
- Tampa, FL
11-24-2022, 12:44 AM #14
- Nov 2022
- amesterdam
I have been using the Johnson lifters, little more Speed Test money than the LS7 but way better quality.
02-01-2023, 01:24 PM #15
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
My 6.0 started tapping this weekend, sent the video to the shop that built the engine, and was told to not drive it and get it to them. The thought is that it's probably lifters but haven't confirmed yet.
Apparently, something may be up with newer GM LS7 lifters, as Texas Speed has recently put a note on their websites page for GM LS7 Lifters that the product has no warranty.
Anyone else been having problems with GM LS7 lifters? Any reasonably priced replacements out there? Running a non-factory cam.SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
04-10-2023, 06:08 AM #16
- Sep 2010
- Bel Air, Maryland
Good news, seems that I had a rocker arm go bad; seems like my lifters may be OK, after all!
Question: Morel Lifters and LS7 Lifters
By LSnewb91 in forum Internal EngineReplies: 4Last Post: 02-04-2016, 07:31 PM -
Lifters
By BashamWS6 in forum Internal EngineReplies: 13Last Post: 12-01-2010, 09:16 PM -
Lifters
By bigrondownhiller in forum Internal EngineReplies: 15Last Post: 12-25-2009, 01:04 PM -
Comp Cam Lifters or ls7 lifters?
By Frankthetank in forum Internal EngineReplies: 6Last Post: 06-03-2007, 12:26 PM -
Best lifters for my car
By Ls1fury in forum DrivetrainReplies: 2Last Post: 03-09-2007, 07:14 PM
