Results 1 to 3 of 3
    Apr 2021
    Pasadena Tx
    Blue
    2009 GMC sierra
    Running E85 on a 2009 GMC sierra 4.8
    I'm curious If I can run E85 in my 2009 GMC Sierra 4.8. In HP Tuners Its got a section for flex fuel and looks like its running a virtual sensor. I do plan to put in an actual sensor once the turbo is complete.
    Dec 2020
    Chandler AZ
    2011 GMC Sierra 1500 2wd
    is your truck 'Flex fuel'
    is the stock gas cap Yellow then it is flex fuel
    PETE
    Oct 2013
    California
    TAN
    07 Chevy Tahoe
    Quote Originally Posted by steved359 View Post
    I'm curious If I can run E85 in my 2009 GMC Sierra 4.8. In HP Tuners Its got a section for flex fuel and looks like it's running a virtual sensor. I do plan to put in an actual sensor once the turbo is complete.
    Personally, I wouldn't run E85, too many fuel and engine problems. For E85's out there, The virtual Flex fuel sensor temporally closes the canister purge valve for a few seconds and monitors info from the fuel system to calculate the ethanol content. This system has to then make adjustments according to what is in the tank in order that the correct fuel consumption and level for the algorithm that is used for the PCM and ECM. When you make short trips and are going from E85 to 87, 89, or whatever you run, your system is constantly monitoring and making changes to compensate for fuel mixtures. Just like anything, the more changes from one to the other, the faster the breakdown of internal components there will be.
    FYI make sure you check NHST for any recalls on this vehicle- 21V052000 the air bag's frontal passenger-side inflator module may need to be replaced.
    As always, check your owner's manual for what your vehicle is rated for.
    Hope this helps.
  1. 06 GMC Sierra FS
    By sercastiK in forum Western Members
    Last Post: 03-30-2010, 11:23 PM
  2. my new 2009 GMC Sierra
    By Zboner in forum GM Trucks
    Last Post: 12-28-2009, 08:17 AM
  3. Dad's sierra
    By FirebirdFever in forum GM Trucks
    Last Post: 04-17-2009, 01:41 PM
  4. 78 gmc sierra vs 295\50's
    By big hammer in forum Kill Stories
    Last Post: 04-07-2009, 06:59 PM
  5. 2009 Z06 or 2009 Viper Roadster
    By Sarge in forum Almost Anything Goes
    Last Post: 11-16-2008, 01:14 PM
