Results 1 to 3 of 3
Thread: 4th Gen Tow Hooks
12-28-2020, 07:49 PM #1
- Nov 2005
- Texas
Red- 2001 Camaro SS
4th Gen Tow Hooks
Are there any tow hook (road racing) options for the 4th Gen Camaro?
Thanks,
Scott
12-29-2020, 05:03 AM #2
Not that I am aware of, but something simple like this would work: https://www.summitracing.com/parts/cee-3440 Granted, depending upon the height of the connection on the tow vehicle the air dam may be an issue as will access to the hook, especially if the car is lowered. Another option would be to mount a hook under the hood, perhaps to a shock tower or tower brace (if applicable) and just tow with your hood raised.
12-29-2020, 07:42 AM #3
4th Gen Tow Hooks
There was a company that had made a bolt on loop that attached to the shock mount but they no longer do. I tried ordering some in Aug. I've been toying with fibbing some out of 1/4" or 3/8" flat stock if I can get my hands on some.
As far as the front goes I picked up a J hook set from Northern Tools for $18 ea. They hook in the same slot that tow trucks and factory use when transporting. There's a hole/slot in the frame that is what it's purpose is. I insert the j hook, attached to my ratchet strap and call it good.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
Tow hooks?
By pajeff02 in forum Drag RacingReplies: 11Last Post: 10-10-2014, 04:56 PM
