Results 41 to 60 of 63
  1. #41
    98 T/A w/ mods, 00 FBVert
    LS1/LS6 rebuild ballpark...
    Availability of LS2 or even LS6 block vs LQ4/9. THE LQ wins.
    As for weight penalty. I can tell you mine doesn't even notice it. I have Hotchkiss 1" drop springs and Bilstein shocks. It didn't drop the nose more than a qtr in between my LS1 and the 403 LQ block.
    00 FB Vert - Stock
  2. #42
    He can make those numbers with a stock LS1 block
    My brain must be defective.
  3. #43
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Yeah, if I can make that power with the LS1/LS6, as long as I dont have a roached bottom end which I shouldn't, I think I will see about rebuilding my block. Should be less confusion. I figure that I will have to buy a new intake and throttle body at that point. I am almost ready to drop it off.
  4. #44
    Sep 2010
    Bel Air, Maryland
    I got a hold of the guy who used to run F-Body Central, and he was able to source me a 6.0 G8 GT block, do a full rebuild of the bottom end, use Texas Speed LS6 heads, and a McCloud clutch kit for about the price other shop was quoting to re-use my block. So I pulled the trigger on it. The 6.0 is at the machine shop!
    He is in VA, just shy of the NC border now, it should be a bit of a drive, but he does good work. He is going to re-use my LS6 intake, and not do anything too Gucci.
    I am very excited now!
    SLP Air Lid/Smooth Bellows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @:
    415 rwhp
  5. #45
    Torquer 2 cam?
  6. #46
    Sep 2010
    Bel Air, Maryland
    Torquer 2 cam?
    Texas Speed 228R cam
  7. #47
    His other favorite cam
  8. #48
    Sep 2010
    Bel Air, Maryland
    I presume its a good cam, right?
  9. #49
    Yeah made around 400 to the tire in the cam only swaps I did back when I worked there. Good street manners. Fun little driver cam
  10. #50
    Sep 2010
    Bel Air, Maryland
    Nice. I am hoping for between 425-450 rwhp and a good torque curve
  11. #51
    I'm betting you be around 415ish with that cam.
  12. #52
    Sep 2010
    Bel Air, Maryland
    Even with the 6.0’s bore and Texas Speed 243 heads?
    415 is still about 8.5 lbs per hp, and I probably shouldn’t be crying, but that would make the setup only 60 hp more than my current LS1 with a stock long block.
  13. #53
    If you look at my signature you'll see what I have and it only put out 450 to the rear. As good as 243's are they still don't flow enough when compared to aftermarket heads.
    My cam is 237/242 @112 LSA .650 lift
  14. #54
    Quote Originally Posted by Whamhammer View Post
    LS1s with stock 241s and LS6 intakes would be around 400. 405-410 was the most I ever saw cam only. This was on a Mustang dyno
  15. #55
    Sep 2010
    Bel Air, Maryland
    Well…. Finally am getting it done, dropping it off to Jason tomorrow morning!
  16. #56
    Sep 2010
    Bel Air, Maryland
    The 6.0L and new clutch job is in the car and running, going to get dyno tuned on Thursday. Cross your fingers!
  17. #57
    Sep 2010
    Bel Air, Maryland
    Dang, 415.6 rwhp, on a Dynojet, pretty much on the nose!
  18. #58
    Who tuned it?
  19. #59
    Sep 2010
    Bel Air, Maryland
    Who tuned it?
    It was Jason, who used to run F-Body Central/Arundel Performance Inc.
  20. #60
    Nov 2022
    amesterdam
    Does anyone have a good ballpark on what a LS1/LS6 rebuild with obvious upgrades (cam, oil pump, headwork) runs these days, from removal and reinstall runs these days?
    Oil is leaking from the oil pan gasket, front timing cover, and rear main; not alot but enough to be certain.
    Trying to work up budgeted funds, and also compare bottom end rebuild against getting a LS2 bottom end.
    Wouldn't hurt to ask any local tuners. They usually are have contacts with builders in their area too.
  1. Help on finding a ballpark estimate for an over haul.
    By Questioner in forum Firebird / WS6
    Last Post: 03-20-2018, 06:28 AM
  2. rebuild ls1...
    By bowtie1999ss in forum Internal Engine
    Last Post: 10-08-2009, 07:14 AM
  3. Rebuild or New??
    By TransAm11973 in forum Drivetrain
    Last Post: 04-01-2008, 07:54 PM
  4. Rebuild of LS1
    By planedad in forum General Help
    Last Post: 04-02-2007, 07:20 PM
  5. ls1 rebuild kit????
    By 1bad99ss in forum Camaro / SS
    Last Post: 03-25-2007, 07:08 PM
