Results 1 to 3 of 3
Thread: Vibration and Shavings in oil
06-03-2020, 03:52 AM #1
- Jun 2020
- Mudgee
White- 2013 VE Clubsport
Hi all,
I Have noticed a vibration around 2000rpm (comes around then, then goes) and maybe at a higher rpm, hard to tell. Ive done a oil change and noticed very small shavings in the oil, some appear to be copper? what should I be looking at before I make the call to strip the engine down?
Did have a misfire prior to noticing this vibration, turns out it was the leads and replaced.
Engine mods etc. Ls3, magnuson supercharger, cam, highflow oil pump.. also engine rebuilt 40k km ago.
Thanks.
06-03-2020, 11:52 AM #2
cut the oil filter open and look for metal or shavings.
if you have them then time to pull the motor.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
01-29-2021, 12:26 PM #3
Very interesting post.
Help: Metal shavings
By red00bird in forum General HelpReplies: 6Last Post: 05-01-2012, 12:20 PM -
Question: Metal shavings on cam while doing ls6 vct
By 98TransAmWs-6 in forum General HelpReplies: 40Last Post: 04-20-2012, 09:03 PM -
vibration
By jsmith564` in forum General HelpReplies: 213Last Post: 02-25-2012, 04:50 PM -
Vibration
By SilverFish in forum Camaro / SSReplies: 3Last Post: 08-22-2008, 02:17 AM -
vibration
By JROBINSON1016 in forum Internal EngineReplies: 5Last Post: 03-20-2007, 05:23 PM
