Results 1 to 2 of 2
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Back of car is tapping...
    Here’s one that I hadn’t heard before, there is a ticking/tapping noise coming from the driver side rear of my car, when I drive. The noise is almost like one would hear if a wheel had a metal valve stem or something tapping against the wheel but I have run of the mill rubber stems and caps.
    Has anyone heard something like that before?
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    Get it up on really solid stands with the suspension compressed and see if you can replicate in the driveway. I had a similar noise after doing some exhaust work and found out it just a large zip tie sliding on the driveshaft and tapping on the balance weight. Simple but annoying.
  1. Help: tapping noise!
    By godless-phoenix in forum Firebird / WS6
    Last Post: 10-15-2010, 07:52 PM
  2. Tapping
    By flipsutter in forum V6
    Last Post: 07-24-2009, 10:34 AM
  3. Tapping Noise
    By David Ray in forum General Help
    Last Post: 05-27-2009, 05:27 PM
  4. tapping noise??????
    By wil2kss in forum General Help
    Last Post: 11-01-2005, 10:30 AM
  5. tap tap tap tap tap tap tap tap tap tapping
    By third_shift|studios in forum Internal Engine
    Last Post: 09-10-2005, 05:15 PM
