Thread: who uses a oil catch can?
05-11-2020, 03:01 PM #1
I was wondering how many guys/girls on here use a catch can?
I go to alot of car shows and I see very few (if any), so the question is, would it help me if I put one on my engine?
Before anybody asks I do not run the car down the drag strip. I just drive the car on the street. And its 100% stock motor.
05-12-2020, 08:46 AM #2
I've had one on since I got it, on both engines. If you're using the OEM POS PCV then definitely get one.
With you being an 02, I would do the LS6 Valley Tray swap and catch can.
Good news is you won't have to notch the block unlike us 98-01's.
Here's the thread to look over.
http://www.ls1.com/forums/f63/ls6-va...r-pics-145557/http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
05-12-2020, 06:18 PM #3
Been running one for a few years now. Stock PCV had rotted away so I changed everything over to -6 hose and fittings with the Mishimoto baffled can.
05-15-2020, 11:40 AM #4
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I’ve been eyeing one for a while, and am about to pull the trigger on a basic model Elite Engineering catch can. A bunch of people run them, because LS1s have a tendency to feed oil into the intake.
Running without one for 211k miles so far but I want a dry intake charge, up until the injectors; I also want to at a T connector inline so I can run SeaFoam through intake from time to time to clean the valves and combustion chamber.
I also don't feel like swapping over to the LS6 plate.
05-16-2020, 08:21 PM #52002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
06-20-2020, 05:30 AM #6
- Sep 2010
- Bel Air, Maryland
Just pulled the trigger in the Elite Engineering catch can, should have it by end of month.
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
Catch Can
By kenro23 in forum General HelpReplies: 10Last Post: 02-18-2011, 04:41 PM -
Pcv catch can?
By GOR1LA in forum Firebird / WS6Replies: 14Last Post: 02-11-2011, 07:42 AM -
Question: Catch can...
By sutie in forum Firebird / WS6Replies: 32Last Post: 02-05-2011, 05:42 PM -
C6 Corvette Catch Can - Catch Me If You Can
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-29-2009, 02:00 AM -
WTB Oil catch can
By Stricken1 in forum Parts Wanted / TradeReplies: 1Last Post: 11-22-2007, 09:51 PM
