Thread: How Much boost is too much boost
12-03-2019, 07:37 PM #1
- Dec 2019
- Virginia
Hi im looking at buying a 2000 Camaro 3.8 V6 5 speed with a little over 114000 miles on it, how much boost would be too much for it how what size turbos would be recommended for a twin turbo setup and injectors?
12-04-2019, 08:58 AM #2
How much? When it sends a rod thru the block.....
But seriously. I've seen several single and twin turbo V6 Firebirds ripping it up at the track on Youtube.
I would be talking with a tuner first, it's possible that they've been down this road before and can offer suggestions. Not too many guys on here have done it to a V6 here.
I do know the 3800 LOVES boost.
Some other areas you're going to need to look at in addition to just the engine is transmission, rear end and suspension. High HP & TQ will always find the weakest link in the drivetrain.
Here are a couple of videos that might help you
00 FB Vert - Stock
06-01-2020, 06:25 AM #3
- Aug 2007
- Corn and Soybean fields
10 to 15 pounds will be plenty of fun. Bottom end won't care unless the tune is on the ragged edge and you get bad fuel
I'd look into Tim King's old Firebird for your answers about twins as I can't remember what he used or what Matt M used on his Grand Prix
01-29-2021, 12:26 PM #4
How much boost...
By ls1camino in forum Almost Anything GoesReplies: 3Last Post: 07-18-2009, 08:59 AM -
Boost Gauge vs Boost/Vacuum Gauge
By ls1camino in forum Forced InductionReplies: 6Last Post: 09-28-2008, 06:02 PM -
Low Boost S/C?
By M-Ten in forum Forced InductionReplies: 36Last Post: 01-26-2008, 01:14 PM -
Boost Baby Boost
By DanWS6 in forum Rocky Mountain MembersReplies: 16Last Post: 04-03-2007, 11:37 AM -
Boost
By Got Boost? in forum Almost Anything GoesReplies: 61Last Post: 08-15-2006, 01:43 PM
