11-21-2019, 06:04 PM #1
- Nov 2019
- Mesa, AZ
Bright Green Metallic- 1998 Trans Am
Running rich & tuner can't figure out why....
NOOB as far as forums, haven't been on one is over a decade so... Just rebuilt my 98 TA. Running a 228 / 232 .600" 114 LSA cam, LS6 heads, ported, milled .030, forged bottom end, approx 11.3:1 compression. FAST 92mm intake & TB. and and LS2 style MAF. Fuel Pressure is a consistent 60psi across the power band. and 36# injectors rated at 36psi @ 43.5 psi fuel pressure. Not punched out past a normal machining process.. so... 350cid? And about 1700 miles on the engine.
At idle @ 930 rpms:
MAF: 1.65 lb/m
MAP: 13.9 "HG
Front o2s: .755 .790
"rear" o2s (bypassed): .450 .450
Abslt TPS%: .4
Calc load%: 4.3
Coolant: 189'
Fuel sys 1/2: closed
IAT: 111'
ST FTRM1%: -29.7
ST FTRM2%: -25.8 PIG RICH on these... I know....
ST FTRM11%: -28.1
ST FTRM21%: -25.0
injectors and fuel pressure regulator / pump are all new... To me it just seems the fuel map is too rich to begin with... from my research all my telemetry makes sense but... why is it running so rich to begin with? Thank you in advance.
11-22-2019, 06:50 AM #2
Is it running rich all the time or until the O2 sensors kick in and start adjusting the tables?
Also is this a real tuner or someone that does it as a hobby?
Not trying to insult anyone, just that I've seen a few too many ppl having HPTuners or Holly EFILive claming they are tuners and know nothing beyond the basic functions.Last edited by SMWS6TA; 11-22-2019 at 06:52 AM.
11-22-2019, 09:01 AM #3
- Nov 2019
- Mesa, AZ
Tuning was done through a local shop with a good reputation on a dyno I know the owner, ironically I used to whoop his ass in the early 2000s with the same car. I believe it’s rich all across the power band as I’m also only getting 15mph. I haven’t looked at the trims under load. I think I’ll do that now.
11-22-2019, 09:09 AM #4
How old are the O2 sensors?
11-22-2019, 01:11 PM #5
- Nov 2019
- Mesa, AZ
12-08-2022, 09:49 AM #6
- Nov 2022
- amesterdam
Question: running to rich
By reaper ws6 in forum General HelpReplies: 8Last Post: 02-08-2011, 08:07 PM -
Question: running rich?
By BlairF in forum V6Replies: 7Last Post: 10-12-2010, 08:13 AM -
My ls1 is running way rich
By 69LS1velle in forum General HelpReplies: 10Last Post: 05-26-2010, 11:58 AM -
Running very rich
By cm1273 in forum Computer & TuningReplies: 2Last Post: 09-10-2009, 10:52 AM -
Running WAY Rich
By Krazy351w in forum General HelpReplies: 6Last Post: 06-05-2007, 09:28 AM
