Thread: A Better Goat
    May 2010
    bc
    97
    A Better Goat
    I will post this in one other place but I will start HERE! Im looking for a car from 1999 to 2006, and I was reading the goats with the ls1 had more punch in HP then the fire, z28? why? then we can get into the ls2 that the goats had >but Im wondering why the goats had more HP from the early ls1s? then the Fire, Z28, SS? Your Thoughts?
    May 2010
    bc
    97
    I like the looks of the fire, ss and not so much of the goat >but What 50hp more goat? and can anyone tell me the weight of a Goat and an ss? Release the Hounds!
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by bikelite View Post
    The GTO weighs about 200 pounds more than an equivalent LS1 SS.
    SLP Air Lid/Smooth Bellows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @:
    415 rwhp
    May 2010
    bc
    97
    That's what I found out that the later ls1s got a few things from the ls2 to pump up horse but still the later fire-cam got a 325 rate but the goat got a 350 rate!! very intro
    98 T/A w/ mods, 00 FBVert
    The early LS1's had crapy heads. But when paired with the 243 heads from the LS6 engine and a better cam profile they perform just as good as the later LS1's. Only main difference between the early and later LS1 blocks is the oil galleys are slightly different other then that the block architecture is the exact same. The early LS1's 97-98 suffered from bad oil pumps but that was fixed in 99. The 99 LS1 is a bastard year because they came with 26lb injectors vs the 28lbs the other years came with. It also had a different cam profile. The 01-02 LS1 blocks were actually LS6 blocks with LS1 cam. That is why there is a difference with the HP/tq between Vette and F bodies. GM couldn't have the F-bodies matching the Vettes now could they.
    00 FB Vert - Stock
  1. WTB CAI for 04 Goat
    By wooddaniel in forum Parts Wanted / Trade
    Last Post: 12-03-2010, 04:13 AM
  2. WS6 vs. Goat
    By Numba1TA in forum Kill Stories
    Last Post: 07-08-2009, 04:55 PM
  3. how hot should my goat run?
    By 05gtoautoX in forum GTO
    Last Post: 08-12-2007, 06:13 AM
  4. Me and the Goat
    By secondgearscratch in forum Kill Stories
    Last Post: 03-01-2007, 07:51 AM
  5. My first L from a Goat!
    By kams95ss in forum Kill Stories
    Last Post: 11-27-2006, 11:36 AM
