Thread: Gto , Firebird, Z28
11-03-2019, 02:49 PM #1
- May 2010
- bc
- 97
Gto , Firebird, Z28
I will post this in one other place but I will start HERE! Im looking for a car from 1999 to 2006, and I was reading the goats with the ls1 had more punch in HP then the fire, z28? why? then we can get into the ls2 that the goats had >but Im wondering why the goats had more HP from the early ls1s? then the Fire, Z28, SS?
11-20-2019, 04:04 PM #2
- Jan 2009
- North Jersey
GTO LS1 had LS6 intake manifold and throttlebody. Also had revised emissions system deleting EGR. I might be wrong, but I think the heads had larger ports than the LS1 in the 4th gen F bodies as well.
11-21-2019, 09:20 AM #3
^^ correct but they also had different heads and cam profile in addition. The GTO's came with the 243/799 heads as the 98/99 had 853's and the 00-02 came with 241's. The C5 97 LS1 came with different heads, can't remember if they were the 241's or something different and different cam profile over the 98 f body LS1's. With the LS6's being phased out due to Corvettes going to the LS2 and the LS6/1 were by then, considered the same block just with different cam profile, intake and heads, between the two the Ls1/Ls6 are regarded as the same engine
The GTO LS2 are a 4" bore vs the LS1's 3.898", came with 243/799 heads and a bigger cam profile, intake was slightly larger over the LS6 for the throttle body however it under performed compared to the LS6 unless it was ported. Also the injectors were different over the LS1 as well as tuning.Last edited by SMWS6TA; 11-21-2019 at 09:27 AM.
12-30-2019, 09:46 AM #4
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
The most important thing to note is that LS1 F-Bodies typically dynoed ~300 rwhp, which is equivalent to what the Corvettes dynoed, with a higher advertised power rating; realistically the F-Bodies power rating was underrated, be it on purpose to lend more street cred’ for the Corvette, or that the drive train on the F-bodies were that much more efficient in tranferring the power to the wheels.
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
For Sale: Firebird gone! 98-02 firebird camaro parts left in my garage
By JayTA98 in forum Parts For Sale / TradeReplies: 26Last Post: 01-26-2023, 09:48 AM -
New Firebird
By fbodyNATION in forum Firebird / WS6Replies: 14Last Post: 06-27-2013, 07:01 AM -
1972 Pontiac Firebird Vs. 2001 Firebird Formula - HPP Paveme
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 09-05-2012, 06:10 PM -
99 firebird
By Getzen_Guy in forum Vehicles For Sale / TradeReplies: 2Last Post: 01-06-2008, 11:55 AM -
Stock Firebird Hood off my 2000 Firebird
By blackbird04 in forum Parts For Sale / TradeReplies: 0Last Post: 09-15-2006, 07:12 AM
