Results 1 to 15 of 15
Thread: Vibrating Headlamp?
08-19-2019, 05:03 AM #1
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Vibrating Headlamp?
Hey guys, my ‘birds passenger side headlamp assembly has been vibrating when I drive the car down the road. I knew the gear was going, so I thought it was that; now the gear died, and I brought the lamp up manually via that knob, and the headlamp is still vibrating going down the road.
Would the chewed up gears still do that, even with the lamp manually raised?
08-19-2019, 06:31 AM #2
It's not the gear, it's the hinge bushing that pivots the light up.
Good luck finding a replacement.
I had to pull one from a salvage yard. I've yet to find a replacement bushing for it.
08-19-2019, 07:48 AM #3
- Sep 2010
- Bel Air, Maryland
You mean this one?
https://www.wc-autoparts.com/1998-20...tor-crank-arm/
Or this?
https://www.wc-autoparts.com/1993-20...-bolt-bushing/
08-19-2019, 08:04 AM #4
00 FB Vert - Stock
08-19-2019, 08:46 AM #5
- Sep 2010
- Bel Air, Maryland
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
08-23-2019, 08:18 AM #6
10-04-2019, 01:02 PM #7
10-08-2019, 07:28 AM #8
I stuck this thread for future reference.
02-14-2020, 06:02 PM #9
- Sep 2010
- Bel Air, Maryland
OK, the bushings didn’t fix it.
In the video I linked, I can see that the motor crank arm is allowing movement/play (so bad that the headlamp socket backs off, before I electrical taped it to the back of the bulb). This was present before and after I replaced the passenger headlamp motor.
https://m.facebook.com/groups/724970...&ref=bookmarks
What causes this movement? The drivers side has nowhere near the amount of play. Do I jeed to replace the crank arm? Is there a fix for the crank arm (like shimming the pivot points)? Is there something else that I am missing?
02-14-2020, 07:03 PM #10
Vibrating Headlamp?
video link no worky
02-15-2020, 06:59 PM #11
- Sep 2010
- Bel Air, Maryland
In a nutshell, the crank arm still demonstrates a range of motion, when the lamp is fully up or down.
It was suggested to me that I adjust the white nylon bumpers that should limit that motion, and if that doesn’t work, that the crank arm is bad and that I need to replace them.
09-21-2020, 05:12 PM #12
Are LED Headlights Really Better?
09-21-2020, 07:12 PM #13
Yes when compared to the 90's headlights, well to be fair, 1986. The same headlight used on Firebirds is the same light used for years on Chevy trucks.
08-22-2022, 08:19 PM #14
- Aug 2022
- Koth
Black- 2018
Hey
I totally agreed with you my problem is solved. I am very happy.
Have a nice day to all.
09-14-2022, 02:18 PM #15
- Sep 2022
- Louisiana
I have a question can I use the 1998 Camaro PCM on a 1998 Firebird
Oil troubles/with vibrating
By RedHot99T/A in forum Firebird / WS6Replies: 9Last Post: 10-12-2010, 05:21 PM -
Will poly mounts cause vibrating.
By Street Fighter in forum Suspension and HandlingReplies: 4Last Post: 05-16-2008, 06:15 PM -
Engine vibrating?
By Street Fighter in forum Internal EngineReplies: 9Last Post: 04-08-2008, 06:45 PM -
Vibrating speaker?
By LgndKller20073 in forum Stereo and ElectronicsReplies: 2Last Post: 09-26-2007, 01:30 PM -
Vibrating at feet. (98 z28)
By nerd4life in forum External EngineReplies: 0Last Post: 10-08-2006, 05:16 PM
