    Member herculesrider1's Avatar
    TX
    '00 TransAm RamAir WS6 M6
    Question Radiator Expansion Tank Hose
    My 2000 T/A has the stock overflow expansion tank directly under the battery. The hose going from the radiator to this expansion tank is very flimsy and feels like it will let go any day. I was wondering if it was possible to replace only the hose? The tank itself is in good condition, but see that there is what looks like an aluminum crimp fitting connecting the aluminum tube to the rubber hose. I don't think there is enough room for a screw type hose fitting clamp to fit in the channel underneath the battery. How would I replace the hose? Thanks in advance for any solutions!
    Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
    98 T/A w/ mods, 00 FBVert
    yes you can. it is standard coolant hose. 2 clamps are what hold it.
    You may have to remove the battery to get to the lower clamp IIRC.
    The house is normally flexible.
    00 FB Vert - Stock
    TX
    I see the top clamp near the radiator neck, and my battery is already out, and see the other clamp, but the lower clamp that is beneath the battery does not look serviceable. It looks like it's clamped and not removable. Yes, the normal hose is flexible, but mine is looking paper thin, not nearly as thick as a new hose would be. Still trying to find out how to remove/replace the lower clamp under the battery....Thanks Scott.
    TX
    Well, I purchased 3/8 hose, and had no problem attaching it to the top radiator neck fitting, but the bottom connection underneath the battery was another story. I got out my dremel tool and put a slimline cutting wheel on it. I lifted up the aluminum line beneath the battery that lays in the tunnel groove and proceeded to cut the aluminum crimp with the cutting wheel being careful to not go too deep, just deep enough to see black rubber. Peeled the aluminum crimp off the fitting and pulled the hose off the aluminum nipple. Got an Ideal screw type hose clamp and clamped the new rubber hose onto the aluminum line. It was thin enough to go down into the tunnel underneath the battery. The hose clamp excess needed to be stuffed down into the tunnel. Job done.
  1. Hose from radiator to throttle body
    By Matto4785 in forum General Help
    Last Post: 05-27-2013, 05:26 PM
  2. Help: Radiator Hose is Swelling up-???
    By TerribleTed in forum General Help
    Last Post: 09-18-2010, 10:06 PM
  3. radiator surge tank
    By David Ray in forum General Help
    Last Post: 08-17-2009, 08:47 AM
  4. Question: coolant recovery tank hose
    By Art99SS in forum General Help
    Last Post: 06-27-2009, 07:45 AM
  5. Lower Radiator hose
    By madelife in forum General Help
    Last Post: 08-19-2007, 01:57 PM
