Results 1 to 2 of 2
    Apr 2019
    Grants Pass, OR
    67 GTO Rear End Gear Ratio
    I’m restoring a 67 GTO, stock 3.55 rear end too low for highway use. Looking to rebuild rear end (add posi-carrier) and would appreciate a suggested ratio and corresponding tire/wheel sizing. 400 cu” engine getting tooled to about 425hsp. Want both acceleration and 70 mph comfort (not 4K rpm). Thank you, Bill in Oregon
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by roosky View Post
    Personally, I’d look at an overdrive transmission conversion, or putting a “Gear Vendors” unit inline after the transmission.
    You could put a 3.08 or something in the rear but I doubt you would he as happy.
    SLP Air Lid/Smooth Bellows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @:
    415 rwhp
  1. Replies: 12
    Last Post: 02-06-2012, 03:35 PM
  2. Question: What is my rear gear ratio?
    By camaroluvr447 in forum Drivetrain
    Last Post: 10-08-2009, 01:37 PM
  3. ?Gear ratio for LS1?
    By SycoJoe69 in forum General Help
    Last Post: 11-15-2007, 09:51 AM
  4. How to tell rear gear ratio?
    By turbojimmy in forum Drivetrain
    Last Post: 08-03-2007, 11:18 AM
  5. 94 z-28 m6 rear gear ratio
    By LT1Redneck in forum Drivetrain
    Last Post: 01-15-2007, 05:43 AM
Tags for this Thread
