    Member herculesrider1's Avatar
    TX
    '00 TransAm RamAir WS6 M6
    120K mi clutch, press plate, flywheel
    Just pulled the trans and pulled off the clutch pressure plate. Here's what I found. I bought the car in '08 and have put 120,000 miles on this clutch, pressure plate, and flywheel. Is this low wear normal? Should I replace it or reinstall it? I don't have a new disc to compare to, so I really don't know. Anyone's opinion would be appreciated! Thanks!
    The first pic is the clutch disc, the second is the pressure plate which still has the ridges in the plate. The flywheel looks the same way with ridges still on the face of the flywheel. What do y'all think? Thanks!
    Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
    98 T/A w/ mods, 00 FBVert
    I responded in the other thread but I'll also add here that it looks like your still have a fair amount of material on the clutch that you still have valleys on the clutch material and the material looks to be quite a bit above the rivets.
    Depending on your driving you could bet another 35-50k miles IMHO.
    TX
    Thanks Scott. I never knew clutches could last this long.
    Depends on the user.
    TX
  1. Question: SPEC Products: Flywheel - Clutch - Pressure Plate etc
    By LimeyZ in forum Drivetrain
    Last Post: 03-16-2012, 05:32 AM
  2. flywheel/pressure plate question
    By SS#1531 in forum Manual Transmission
    Last Post: 09-05-2007, 09:16 PM
  3. LS6 Clutch and Pressure Plate, LS2 Flywheel FOR SALE
    By CChatter9 in forum Parts For Sale / Trade
    Last Post: 09-27-2006, 03:38 PM
  4. z06 clutch for sale, pressure plate clutch disk and flywheel
    By themack56 in forum Parts For Sale / Trade
    Last Post: 07-06-2006, 07:15 PM
  5. Replies: 4
    Last Post: 03-09-2006, 05:01 AM
