    Junior Member daveinstl's Avatar
    Saint Louis
    Blog Entries
    1
    2002 Camaro SS
    2002 Camaro Driver Side Power Window Working Intermittently
    The driver side window recently started working intermittently. Sometimes it's fine, sometimes it goes part way up and I have to wait a while and it will eventually go up, sometimes a little at a time. I did replace the front speakers a few months back - don't think I loosened any other wires but it's possible. Everything else, including the radio, works fine. I tried replacing the switch because it was cheap and easy but it didn't help. Loose wire to the motor? Bad motor? Something else? Thank you in advance for your help.
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Sounds like the motor is going bad. Very typical for these cars. Just replaced the passenger motor on our T/A a couple months ago (and added the Autotrix window fix kit). Had to replace both on my old SS at different times.
    98 T/A w/ mods, 00 FBVert
    ^^this
    Saint Louis
    Blog Entries
    1
    2002 Camaro SS
    Well, I guess it was the motor. I replaced it and it seems to be working OK. It wasn't really that bad to replace except I had to get some self-drilling screws because I couldn't get the nuts and bolts that came with it seated properly.
    Quote Originally Posted by daveinstl View Post
    Yep I had to do something similar on the old SS for the same reason. Didn't have any trouble this last round. Glad you got it fixed
  1. Wanted: Driver's side power window/door lock switch for a Camaro
    By White Knight in forum Parts Wanted / Trade
    Last Post: 02-05-2012, 12:16 AM
  2. Wanted: Driver side power window/ mirror switch bezel.
    By bluefields88 in forum Parts Wanted / Trade
    Last Post: 10-25-2011, 09:40 PM
  3. Wanted: Camaro 4th Gen Driver Side Window Controls
    By KMdef9 in forum Parts Wanted / Trade
    Last Post: 09-17-2009, 08:15 AM
  4. Question: Driver Side Power Window
    By CobraKilla in forum General Help
    Last Post: 06-12-2009, 02:58 AM
  5. Wanted: Fbody Driver Side Power Window Motor
    By Zaccagnini in forum Parts Wanted / Trade
    Last Post: 10-23-2008, 12:23 AM
