Thread: Stange engineering rear end
07-31-2018, 05:31 PM #1
Heya everyone! I am considering swapping out my stock 10bolt with a Strange S60. Looking at the website there are a few options. Any info or opinions?
https://www.strangeengineering.net/p...y-mounts.html/
Thanks all!
Chris
08-01-2018, 03:34 AM #2
When I purchased our Moser 12 bolt, I added the welded relocation brackets, made sure it was compatible with ABS/TCS (for our car, I assume yours is the same), went with 3.73's as we are an A4, 1350 U-joint cradle, 33 spline axles (more = stronger) and opted for the True Trac posi unit. I also had to purchase a shorter driveshaft due to the size of the Moser differential being larger than the stock 10 bolt.
08-01-2018, 05:27 AM #3
Strange has some good customer support. They should be able to answer any questions you might have. They help me a ton with my driveshaft order.
00 FB Vert - Stock
08-01-2018, 08:51 AM #4
Strange does have very good customer service that's for sure and will go above and beyond to make sure everything is right. I had an issue with my driveshaft and they were able to help me out correcting a u-joint fitment issue. They sent me a couple of u-joints to try out since mine was a little funky.
98 WS6 M6 ASC #2647
Forged Custom 408 w/Vortec YSi
TSP vs. Speed Engineering 1 7/8 LT's ORY
By BlCk02WS6 in forum External EngineReplies: 19Last Post: 02-19-2015, 02:04 AM -
Genetic Engineering
By SP33Daddict in forum Almost Anything GoesReplies: 9Last Post: 03-11-2011, 07:11 AM -
Badge Engineering Fun
By LSCyaL8R in forum Almost Anything GoesReplies: 17Last Post: 11-03-2009, 01:47 PM -
SLP engineering decals
By topcat in forum Appearance SectionReplies: 5Last Post: 08-19-2009, 06:11 PM -
For Sale: SLP Engineering decals
By LS1Z28 in forum Parts For Sale / TradeReplies: 0Last Post: 08-17-2008, 11:11 AM
