Results 1 to 10 of 10
    Jun 2006
    B.C. Canada
    2000 Pontiac Firehawk TA
    Suspension help please
    So this weekend I installed the Eibach / Bilstein kit in my 2000 Firehawk. Got everything done as per the shop manuals ( and youtube ). I've done a couple third gens so I figured it would be easy. Took it for a drive and I can hear a suspension clunk on both front corners. Only hear it over bumps. Also, I can feel it slightly in the floor. I've retorqued all but the lower shock mounts. I will check those tomorrow. Any ideas what could be doing this ? What did I miss ?
    98 T/A w/ mods, 00 FBVert
    I think I saw your post on FB. Did you check the shock nut? Did you tighten it with the spring compressed?
    Jun 2006
    B.C. Canada
    I did not post on FB, someone else with the same issue ? I tightened the top nuts with the springs compressed. Maybe not tight enough ? Good amount of threads showing on both sides, I remember that much.
    2000 Firehawk - LS6 - SLP Headers, subframe connectors and strut tower brace
    Did you remember to put back in the rubber isolater?
    Jun 2006
    B.C. Canada
    Meaning at the top where the nut is ? Or the bottom where the spring sits ?? Both in place.
    There's a isolater that sits between the spring and the body.
    Jun 2006
    B.C. Canada
    Yes, it's a two piece combo. It's all there. I'm stumped and annoyed with myself. I need an alignment anyway, so I'm thinking I'll have the shop check it out while it's there. Unless I can figure something out soon.
    Firestone does free alignment checks. It's how I found out why my Grand Prix would pull to the left on braking. The Lower A arm had a torn bushing.
    00 FB Vert - Stock
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Is there a possibility that it could be the A-arms?
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    Jun 2006
    B.C. Canada
    Pulled it all out again tonight. I re-compressed the springs and snugged down the shock shaft nuts. Solid as a rock now. That's all it was. I feel kinda dumb but relieved as well. Live and learn ! Thanks for the suggestions anyway guys.
  1. Front Suspension Work / Completed Rear Suspension
    By bhunter0830 in forum Suspension and Handling
    Last Post: 07-02-2013, 01:23 PM
  2. Front Suspension Work / Completed Rear Suspension
    Last Post: 04-13-2013, 05:44 AM
  3. Corvette Suspension Rebuild - The C4 Suspension Ad
    By Ed Blown Vert in forum Corvette
    Last Post: 12-15-2009, 10:30 AM
  4. Pontiac G8 Pedders Suspension Kit - Suspension Red
    Last Post: 12-22-2008, 06:50 AM
  5. 1967 Pontiac Firebird Suspension Upgrade - Suspension Ascension
    Last Post: 01-17-2008, 04:50 PM
