Thread: slave adjusting
07-16-2018, 04:30 AM #1
- Jun 2012
- florida
slave adjusting
i was watching a show where the guy was talking about adjusting the bearing clearence. he measured the distance from the bearings to fingers but never mentioned how to change distance. different spring???? when the clutch is not depressed, does the bearing touch the fingers?
07-16-2018, 08:11 AM #2
The fingers should touch the slave a little. Not enough that they're pressing in more than an 1/8". Shims are mostly used to bring the slave closer to the fingers because of the aftermarket bell housings or clutch kits are slightly different then OEM depths.
I have a QuickTime SFO BH and Monster stg 4 clutch and did not need to use any shims.
07-16-2018, 09:42 AM #3
I run a SPEC 3+ and had to use a slave shim. My old RAM clutch didn't require a shim.
98 WS6 M6 ASC #2647
Forged Custom 408 w/Vortec YSi
07-16-2018, 10:05 AM #4
neither did my LS7 clutch kit.
adjusting my konis
By bpopham22 in forum Suspension and HandlingReplies: 14Last Post: 04-21-2011, 08:52 AM -
adjusting clutch
By steves2000ss in forum Manual TransmissionReplies: 3Last Post: 06-09-2009, 04:50 PM -
TM adjusting 07 z06
By extanker in forum CorvetteReplies: 2Last Post: 05-12-2008, 04:25 PM -
Adjusting Koni SA's?
By ErikElvis in forum Suspension and HandlingReplies: 7Last Post: 08-20-2006, 07:03 AM -
Help!! Adjusting Phb....
By fspeedster in forum Suspension and HandlingReplies: 1Last Post: 03-09-2006, 06:50 AM
