06-20-2018, 04:36 PM #1
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Have anyone used type f trans fluid in there 99 trans am?
Have anyone used or is using type F fluid in there 99 or later trans am trans?
06-21-2018, 03:12 AM #2
No, and I do not really recommend it either. Using Type F in a GM transmission is an old rodder's trick for firmer shifts and better feel. The rule of thumb these days is to only use the older style fluids - Type F, Dex III, etc... in older GM transmissions like TH350, TH400, 2004R, and so forth. The newer transmissions should all utilize Dex VI. There was a good article about this exact same question in a recent issue of Hagerty, I believe.
06-21-2018, 04:04 AM #3
I'll add this. the older T56 like in the 98 only like Dexron III transmission fluid. Tick suspects that the IV I put in killed my transmission and required my rebuild from them. They believe IV eats away at the friction material on the syncros and once they're gone everything else starts to go to shit.
00 FB Vert - Stock
06-21-2018, 09:20 AM #4
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
06-22-2018, 03:23 AM #5
Only two ways that I know of -- physically removing it from the car and dumping it out or a power flush where fluid is drained and added, usually via a cooler line, with the engine running. The transmission basically pumps out the old fluid on its own while a flush machine adds the same amount back in. Not optimal, but you could probably disconnect the return line and let it push out a quart or two. Shut down, top off the fluid and repeat until you have clean fluid. I would not do this though until checking the flow paths to ensure that nothing internal will be left running dry during the manual flush process. So long as the cooler return line is simply dropping the fluid back into the pan this would work just fine.
Trans fluid
By johnfin in forum Firebird / WS6Replies: 4Last Post: 08-02-2012, 05:22 AM -
Ls1 Trans using Type F fuild.
By Street Fighter in forum Automatic TransmissionReplies: 0Last Post: 10-01-2011, 03:44 PM -
Question: Trans fluid
By HOLLYWD69 in forum Automatic TransmissionReplies: 0Last Post: 10-09-2009, 06:49 AM -
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
type???trans fluid 460E
By Ken Glowacky in forum Automatic TransmissionReplies: 3Last Post: 12-02-2007, 05:20 PM
