Thread: Nitto 555R
    Junior Member AtLarge's Avatar
    In a house
    Bright Metallic Blue A4
    1999 WS9
    Nitto 555R
    Can I use these on all four or only on the back? I would to be able to rotate them front to back like usual.
    I was here before the server crashed.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you can use them on all four corners. use the 555R II those are autocross tire version with stiffer sidewalls.
    In a house
    1999 WS9
    Thanks for the reply. Guess I didn't really look hard enough to see the G2. I was just going to order the standard R from my local Discount Tire store. That is a good point. The R has a V rating whereas the G2 has a W rating.
    98 T/A w/ mods, 00 FBVert
    Nitto 555R
    I'm using the 555G2's and honestly I notice no difference. I love the 555's. They help greatly if caught out in a rain storm. Not that I go looking for them but where I live it can rain at any time.
    00 FB Vert - Stock
    May 2019
    Cruise
    How are you liking the Nitto tires?
    love 'em.
    Great for my needs. I'm fixing to order a set for the Vert. If you live up north you might want an all season tire. They're rate as a summer use tire, they don't like temps below 30 degrees. Wet roads they have good traction.
    In a house
    1999 WS9
    Thumbs up
    Quote Originally Posted by heartstrong View Post
    I went with the 555R and 96V rating. Grippy and zero complaints here.
    May 2020
    Phoenix, Arizona, USA
    Nice choice of tires. I was supposed to go for Nitto but settled with the Toyo Country A/T terrain tires that went on sale in 4wheelonline.
  1. Nitto NT-01 or 555r's?
    By bgable in forum GTO
    Last Post: 01-15-2009, 10:04 AM
  2. nitto 555r ?
    By blackbirdbrain89 in forum Wheels and Tires
    Last Post: 12-26-2008, 04:22 PM
  3. nitto 555r
    By silverz28camaro in forum Drag Racing
    Last Post: 03-29-2007, 05:58 AM
  4. FS: Nitto 555R DR
    By 600rwhpSS in forum Parts For Sale / Trade
    Last Post: 06-10-2006, 10:01 AM
  5. Nitto 555r's FS
    By HASTINGSRJ in forum Parts For Sale / Trade
    Last Post: 04-29-2006, 10:22 AM
