Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    mrr23 mod thread
    i'll be posting up the modifications i'll be doing to my 2014 2SS in this thread. currently untouched. as soon as the air intake gets here, i'll post pictures. i'll also be getting the hood heat extractor hydropdipped in carbon fiber. thinking about doing that as well with the grill inserts. i did test the rear wheels and tires on the front for clearance. looks good. so thinking about buying another set of rear wheels and put 315/35-20. a bit wide for the 9" wide wheels. maybe i'll try to find oem looking wheels in 10" wide.
    Looking forward to seeing your progress.
    98 T/A w/ mods, 00 FBVert
    How you liking the 14'? My niece's BF just got a 2010 SS. He's loving it.
    orlando, fl
    2014 camaro 2ss/rs
    enjoying it so far. pretty peppy being stock.
    orlando, fl
    2014 camaro 2ss/rs
    sent my heat extractor and engine cover off to be hydrodipped in carbon fiber. the engine cover will only be dipped in the black areas. leaving the silver areas exposed.
    orlando, fl
    2014 camaro 2ss/rs
    orlando, fl
    2014 camaro 2ss/rs
    orlando, fl
    2014 camaro 2ss/rs
    replaced stock air intake with this one
    http://www.ls1.com/forums/f116/air-i...nstall-187457/
    orlando, fl
    2014 camaro 2ss/rs
    the car lot decided to wash the wheels with an acid. this ruined the calipers. so i painted them black with caliper paint
    before
    after
    orlando, fl
    2014 camaro 2ss/rs
    Muffler delete with stock tips
    how's it sound?
    orlando, fl
    2014 camaro 2ss/rs
    Pretty good. Barely noticeable at idle and cruise in car. Nice deep tone outside car. Gets louder at WOT, but not obnoxious. Still have mid resonator on car.
    orlando, fl
    2014 camaro 2ss/rs
    orlando, fl
    2014 camaro 2ss/rs
    I pick up my hydrodipped parts tomorrow
    orlando, fl
    2014 camaro 2ss/rs
    finally put the hydrodipped parts on
    Looks great!
    orlando, fl
    2014 camaro 2ss/rs
    more parts on the way
    orlando, fl
    2014 camaro 2ss/rs
    runnning my VIN and i found out i have the RS package as well.
    AEF WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN EXPRESS UP/DOWN PASS PWR WINDOW(AEF)
    AE4 SEAT FRT BKT, SPORT SPORT FRT BKT SEAT(AE4)
    AFM INTERIOR TRIM CONFIG #13 INT TRIM(AFM)
    AKQ ADJUSTER SEAT, POWER, 6 WAY, VERT, PASS 6-WAY PWR SEAT ADJUSTER(AKQ)
    AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0)
    AMM ADJUSTER FRT ST POWER, 6 WAY, DRIVER 6-WAY PWR FRT ST ADJ(AMM)
    ATG LOCK CONTROL, ENTRY REMOTE ENTRY, STANDARD RANGE STD RANGE REMOTE LOCK CONTROL(ATG)
    AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING RR SEAT RR FACING CHILD RESTRAINT PROVISIONS(AT8)
    AXG WINDOW PWR OPERATED-EXPRESS UP/DOWN DRVR EXPRESS UP/DOWN PWR DRVR WINDOW(AXG)
    AXJ VEHICLE TYPE PASSENGER CAR PASSENGER CAR VEH TYPE(AXJ)
    AX2 COMMON KEY,VEHICULAR UNIQUE VEH UNIQUE COMMON KEY(AX2)
    AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE DRVR & PASS FRT SIDE & ROOF INFLATABLE RESTRAINT(AY0)
    BD8 MOLDING ROOF BODY COLOR BODY COLOR ROOF MLDG(BD8)
    BTV CONTROL REMOTE ENGINE START REMOTE CONTROL ENGINE START(BTV)
    B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
    B36 MAT,LUGGAGE COMPARTMENT LUGG COMPT MAT(B36)
    B56 ORNAMENTATION,EXTERIOR,ROCKER PANEL MOLDING COLORED RKR PNL MLDG(B56)
    C67 AIR CONDITIONER,FRONT,ELECTRONIC CONTROLS A/C FRT ELEC CONT(C67)
    C93 LAMP INTR, AMBIENT AMBIENT INTERIOR LAMPS(C93)
    DBX MIRROR I/S R/V LT SENSITIVE, VEH COMMUNICATION SYS CONTROL I/S R/V MIR W/LIGHT SENSITIVE & VEH COMMUNICATION CONTROL(DBX)
    DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE DIRECTIONS & CONNECTIONS SERVICE PKG(DCP)
    DD1 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED LT SENSITIVE LH D REMOTE O/S LH & RH MIR,HTD & LIGHT SENSITIVE LH SIDE ONLY(DD1)
    D75 HANDLE O/S,DR,BODY COLOR O/S BODY COLOR DR HDL(D75)
    D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80)
    EAL TRIM SEAT LEATHER, SOLEIL KEISEL, MINI PERF SEAT TRIM(EAL)
    EF7 COUNTRY UNITED STATES OF AMERICA (USA) U S A(EF7)
    FCR TRIM DOOR LIGHT PIPED, BACKPAINTED DOOR TRIM(FCR)
    FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING SPECIAL SUSP(FE4)
    FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
    FHO VEHICLE FUEL GASOLINE E10 E10 GASOLINE FUEL TYPE(FHO)
    GBA PRIMARY COLOR EXTERIOR, BLACK (G) EXTERIOR COLOR(GBA)
    GW6 AXLE,REAR,3.27 RATIO 3.27R(GW6)
    G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
    I14 ENGINEERING YEAR 2014 ENGINEERING YEAR 2014(I14)
    JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
    KA1 HEATER - SEAT ST HTR(KA1)
    KG4 GENERATOR 150 AMP 150 AMP GEN(KG4)
    KTI KIT, TIRE INFLATOR TIRE INFLATOR KIT(KTI)
    LHD VEHICLE DRIVE LEFTHAND DRIVE LEFT HAND DRIVE(LHD)
    L99 ENGINE GAS, 8 CYL, 6.2L, SFI, ALUM, GM 6.2 (L99)
    MAH MARKETING AREA NORTH AMERICA NORTH AMERICA(MAH)
    MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
    MYC TRANSMISSION AUTO 6 SPD, HMD, 6L-80 6-SPD A/TRANS(MYC)
    M97 SHIFTER INTERLOCK BRAKE, TRANS BRK TRANS SHFT INTLK(M97)
    NT7 EMISSION SYSTEM FEDERAL, TIER 2 TIER 2 FED EMIS(NT7)
    NV9 STEERING - POWER, ELECTRIC
    NZL CONTROL STEERING WHEEL, RADIO/CRUISE CTRL, REDUNDANT CTRLS RADIO & CR/CONT REDUNDANT CONTROLS AT STRG WHL(NZL)
    N10 EXHAUST SYSTEM,DUAL D/EXH(N10)
    N34 STEERING WHEEL LEATHER, 3 SPOKES LEATHER STRG WHL(N34)
    OSH PLANT CODE-OSHAWA 1 ONT,GM OF CANADA OSHAWA,ONT ASSEMBLY PLANT(OSH)
    R0C TIRE ALL P245/45R20 FRT XL 103Y BW HW4 & P275/40R20 TIRE(R0C)
    R42 WHEEL 20 X 8.0, J, FRT & 20 X 9.0, J, RR, ALUMINUM, DESIGN 4 ALUM WHEEL(R42)
    R9N CONTROL - SALES ITEM NO. 89
    SBF RESTRAINT SEAT BELT VAR. 1 ST BELT RESTRAINT VAR. 1(SBF)
    SGC PROCESSING TIRE AND WHEEL SPARE, NOT DESIRED SPARE TIRE & WHEEL NOT DESIRED(SGC)
    SLM SALES PROCESSING - STOCK ORDERS
    SRM MODEL CONVERSION CHEVROLET 2SS CHEVROLET 2SS MODEL CONVERSION(SRM)
    SRU SALES PACKAGE CONVENIENCE AND CONNECTIVITY PACKAGE VAR 2
    TB8 HEADLAMPS CONTROL RH RULE OF THE ROAD RH RULE OF THE ROAD HEADLAMPS CONTROL(TB8)
    T3N LAMP SYSTEM DAYTIME RUNNING, SEPARATE CAVITY SEPARATE CAVITY FOR DAYTIME RUNNING LAMPS(T3N)
    T3Y LAMP FRT FOG, PROJECTION TYPE PROJECTION FOG LAMP(T3Y)
    T4F HEADLAMPS HIGH INTENSITY DISCHARGE HIGH INTENSITY DISCHARGE HEADLAMPS(T4F)
    T83 HEADLAMPS CONTROL AUTOMATIC ON-OFF AUTO ON-OFF HEADLAMPS CONTROL(T83)
    UDD DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC) DRIVER INFO ENHANCED DISPLAY(UDD)
    UDY INFOTAINMENT DISPLAY COLOR INFO DISPLAY (CID) 7", WVGA, TOUCH SCREEN INFOTAINMENT COLOR DISPLAY W/7" TOUCH SCREEN & WVGA(UDY)
    UD7 SENSOR INDICATOR NEAR OBSTACLE DETECTION/REAR PARKING ASSIST RR PARKING ASSIST/OBSTACLE DETECTION SENSOR(UD7)
    UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
    UG1 OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
    UHQ RADIO AM/FM STEREO, SINGLE CD, MP3 (AUX IN), USB, NAVIGATION (GMNA) STEREO W/SINGLE CD,MP3,USB,NAVIGATION FOR NORTH AMERICA(UHQ)
    UJM TIRE PRESS INDICATOR MANUAL LEARN MANUAL LEARN TIRE PRESS IND(UJM)
    UMN SPEEDOMETER INST, MILES & KILO, MILES ODOMETER MPH & KPH SPEEDO W/MILES ODOMETER(UMN)
    UMQ GAGE AUXILARY, MULTIFUNCTION MULTIFUNCTION AUX GAGE(UMQ)
    UP9 WIRELESS INTERFACE SHORT RANGE,VOICE RECOG,MUSIC,NAV,STREAMING AUDIO SHORT RANGE WIRELESS W/VOICE RECOG,MUSIC,NAV, STREAMING AUDIO(UP9)
    UQA SPEAKER SYSTEM PREMIUM PERFORMANCE ENHANCED AUDIO PREMIUM SPKR SYSTEM(UQA)
    USR RECEPTACLE USB USB PORT/RECEPTACLE(USR)
    UTJ THEFT DETERENT ELECTRICAL, UNAUTHORIZED ENTRY UNAUTHORIZED ENTRY THEFT DETERENT(UTJ)
    UVC CAMERA REAR VIEW REAR VIEW CAMERA(UVC)
    UV6 DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
    U2K DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
    U77 ANTENNA RR WINDOW, RADIO RR WDO ANT(U77)
    VRG VALUE ADDED ASM COCKPIT VALUE ADDED COCKPIT(VRG)
    VRH VALUE ADDED ASM STEERING COLUMN VALUE ADDED STRG COLUMN(VRH)
    VRK VALUE ADDED ASM ROOF TRIM UPLEVEL ROOF TRIM(VRK)
    VRL VALUE ADDED ASM FRONT HORIZONTAL SUSPENSION HORIZONTAL FRT SUSP UPGRADE(VRL)
    VRM VALUE ADDED ASM FRONT VERTICAL SUSPENSION VERT FRT SUSP UPGRADE(VRM)
    VRN VALUE ADDED ASM REAR SUSPENSION RR SUSP UPGRADE(VRN)
    VRR VALUE ADDED ASM TIRES & WHEELS TIRES & WHEELS UPGRADE(VRR)
    VY7 KNOB,TRANSMISSION CONTROL LEVER,LEATHER LEATHER SHFT KNOB(VY7)
    VZE VIN MODEL YEAR 2014 VIN MODEL YEAR 2014(VZE)
    V8D VEHICLE STATEMENT US US VEHICLE STATEMENT(V8D)
    WRS MERCHANDISED PKG RALLY SPORT (RS) RALLY SPORT PKG(WRS)
    WZI CONTROL STEERING WHEEL, TRANSMISSION, REDUNDANT CONTROLS TRANS REDUNDANT CONTROLS AT STRG WHL(WZI)
    XL7 FREQUENCIES RATING 315 MHZ LONG DISTANCE 315 MHZ FREQ(XL7)
    XR5 FILTER POLLEN POLLEN FILTER(XR5)
    01A TRIM COLOR SEAT JET BLACK SEAT TRIM COLOR(01A)
    1AS TRIM COLOR DR PANEL GRAPHITE SILVER/ICE BLUE PIPING DR PANEL TRIM COLOR(1AS)
    1SZ PACKAGE OPTION- (1SZ)
    2SS PACKAGE SS OPTION 2 "SS" PKG 2(2SS)
    3CJ MOLDING I/P GRAPHITE SILVER, POLYCARBONATE I/P MOLDING COLOR(3CJ)
    4AA INTERIOR TRIM JET BLACK INT TRIM COLOR(4AA)
    5A7 SPARE WHEEL DELETION 5A7)
    6X1 COMPONENT FRT LH NON-COMPUTER SEL SUSP SUSP(6X1)
    7X1 COMPONENT FRT RH NON-COMPUTER SEL SUSP SUSP(7X1)
    8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP SUSP(8X2)
    9L3 TIRE SPARE DELETE 9L3)
    9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP SUSP(9X2)
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Yep, on the 5th gen if you have halos and your SS emblem is red, that points to it being an RS/SS.
    Member hardtrailz's Avatar
    Jul 2016
    SE IN
    Blue Green Chameleon
    2001 Trans Am Vert
    That is looking very good!
    I think i like the black calipers. Might have to do that next time I pop the wheels off mine.
    2001 Trans Am Vert
