    High Point NC
    MGM
    Pontiac G8 GT & 99 Z28 6M
    1st Suspension mod Opinions
    I am thinking about either getting the tunnel mounted adjustable torque arm or Adjustable Lower control arms with relocation brackets. My car is a Stock ride height 6M.
    I do not want any clunking or as little as possible. But some more rear tire grip would be cool.
    98 T/A w/ mods, 00 FBVert
    Then you want a full length torque arm. If go with UMI get the Torque Arm relocation crossmember. It will talk the TA,off the tail cone of the transmission.
    LCA's are always a good choice.
    00 FB Vert - Stock
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    LCA's and better tires will probably do the most for better tire grip. You didn't mention what tires you currently have on the car so I'm assuming standard street radials.
    Sent from my SM-G955U using Tapatalk
    High Point NC
    MGM
    Yes 245 hankooks. Ok lac's with relocation brackets.
    87 GN 7.75 1/8th @ 90MPH-SOLD
    88 GTA AL driveshaft 350 TPI Auto 9.2 76mph
    08 G8 GT 7.88 1/8TH 93MPH
    99 Z28 SLP Lid Magnaflow Cat Back Hurst Shifter Tuned by Frost BMR LCA
    Yes. I would get at least a single adjustable LCA. It lets you make the adjustments later on if you get better springs or change ride height.
    The reason I said full length torque arm is the short ones tend to make some noise.
    Scott is right. When you install the lower control arms with the relocation brackets, you want to install the lower control arm into the lowest hole of the bracket.
    And once you get in some hp mods consider welding in the brackets. I snapped one early this yr. Had to weld them to my 8.8 rear.
    But I'm also putting 450 ftlbs of tq to my rear.
    High Point NC
    MGM
    BMR had a clearance sale for boxed LCA so I picked a set up. I'm going to install them first check out the rear for any other issues or bad bushing then put the relocation brackets on.
    High Point NC
    MGM
    SMWS6 can you link me the torque arm setup your referring to.
    Is this for a G8 or a F body?
    High Point NC
    MGM
    F body.
    Greensboro, NC
    2002 Trans Am WS6 M6
    1982 - 2002 GM F-Body Transmission Mounted Adjustable Torque Arm. You want that one from umi and get the torque arm relocation bracket so you don't snap the transmission tail shaft.
    Something else to look at while your under there is getting a Midwest chassis driveshaft safety loop. Theirs tuck up into the drive shaft tunnel unlike other brands. Braces the tunnel and provides some safety in case the drive shaft ever breaks
  1. Front Suspension Work / Completed Rear Suspension
    By bhunter0830 in forum Suspension and Handling
    Last Post: 07-02-2013, 01:23 PM
  2. Front Suspension Work / Completed Rear Suspension
    Last Post: 04-13-2013, 05:44 AM
  3. Corvette Suspension Rebuild - The C4 Suspension Ad
    By Ed Blown Vert in forum Corvette
    Last Post: 12-15-2009, 10:30 AM
  4. Pontiac G8 Pedders Suspension Kit - Suspension Red
    Last Post: 12-22-2008, 06:50 AM
  5. 1967 Pontiac Firebird Suspension Upgrade - Suspension Ascension
    Last Post: 01-17-2008, 04:50 PM
