Results 1 to 11 of 11
Thread: Help please
    Member screamin chicken's Avatar
    sc
    Black, Red, Silver Jade
    00 WS6,95 Ta, 69 R code
    Help please
    my 2000 ws6 has 40,xxx, cant remember the last time i drove it , nobody
    drives it, I have a MCcleod STreet twin clutch, I get in it today to drive it, and there is no pedal, i added fluid , still nothing
    Slowly pump the clutch pedal several times and see if it starts to come back. Then check for fluid on the ground under the car.
    sc
    I did and nothing, I guess Ill have to find the bleeder valve... Like I said I drove the car months ago with no problem , the resovior was dry , I added fluid so I ll try bleeding Thank you...
    Brake fluid (which is probably what is in the reservoir) will dissipate after it drips onto a garage floor. Not sure how something with a boiling point north of 470 degrees does that, but that's what happens.
    98 T/A w/ mods, 00 FBVert
    Look for missing paint along the body from the mc to the slave. If you have a leak you'll find it that way quick. Brake fluid dissolves paint quickly.
    If you decide to replace the master get a Tick Performance MC. Well, well worth the money.
    00 FB Vert - Stock
    sc
    Thanks Ill look for that.
    sc
    OK , update.... I bought a pump from Advance Auto, I tried to pump the fluid through it to get the air out , nothing. So I just started pushing th pedal to the floor until I actuall got a pedal, it was hard , and normal feeling. So I take it for a ride, and it was perfect, then about 2 miles into the ride i could feel the pedal getting soft , and realeasing more at the bottom, I still just drove it, about 15 mins. into the ride I decided I better get it home, I cant go into reverse, and its almost impossibe to get into any other gear, So I assume I have to bleed the master???
    2007 Yukon XL (sold)
    2014 Z71 LTZ 3LZ (sold)
    2010 Escalade Platinum AWD , 6.2
    2017 Silverado HC , 4x4, 6.2
    2000 WS6 ASC#2300 Holly LS6 intake, TR Custom grind cam, Mac Mids w/ ORY,Hotchkis LCA's, PHB, BMR Extreme STB, BMR re-location brackets,Eibach Sportlines, GMMG, Mccleod Pro 5.0, SLP SFC's, OEM ZO6 wheels
    1995 TA
    1969 R code Mach I my new project
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Yes it will have to be bled. If it was empty long enough you could have corrosion inside the master or slave. If that is the case you might as well replace it.
    sc
    well I assume it was dry for months, so i guess thr tick Performance is the way to go....I can just do the Master, and slave correct....
    Greensboro, NC
    2002 Trans Am WS6 M6
    Tick sells a package with everything you need I believe or you can call them and they will go over it all with you.
    sc
    I think I will just do the slave, and the little resivor , I assume that is the Master for the Clutch, The Throwout liiks more into what I can do on my back.... Thanks
