Results 1 to 18 of 18
Thread: Oil pressure sensor
08-06-2017, 10:45 AM #1
- Jun 2012
- florida
Oil pressure sensor
I bought the standard generic sensor and its too long. Is that a problem. Also what should i put on the threads.
08-08-2017, 08:36 AM #2
That's not the correct OPSU. Yes it is an issue. You may not be able to thread it down far enough and get leaks.
Anti-seize on the threads.
01-30-2019, 07:01 PM #3
I know this is an old thread, but what is the size of the special socket tool to install the OPSU. I have read on other posts a 32mm socket....that seems WAY too big...
Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
01-30-2019, 07:49 PM #4
Oil pressure sensor
Not sure I just picked one up from Oreillys for $10
00 FB Vert - Stock
01-31-2019, 10:48 AM #5
Thanks Scott. I'll try not to bother you so much....looks like you are challenged for time...Oh, and I know about the little wifey feeling ignored because I'm out in my garage paying attention to the other babe in my life...and I thought I was the only one getting razzed all the time for working on her so much!!! Love the build you are doing!
01-31-2019, 12:10 PM #6
No trouble at all...ask away....
01-31-2019, 12:45 PM #7
Ok, I saw you mentioned using anti-seize on the OPSU. How about when torquing down the intake manifold bolts to the whopping 89 in/lbs? Thread locker or anti-seize?
01-31-2019, 01:14 PM #8
That's inch lbs not foot lbs. 89 is about 7 ft lbs
I never use anti-seize on the OPSU, I wouldn't be against some oil on the thread though. Not sure where or why I would say that.
Here's a thread on the tq specs for LS1.
https://www.ls1.com/forums/f6/torque...motors-175530/
01-31-2019, 02:13 PM #9
I will file that one. Thanks! So, you wouldn't use anything on the intake manifold bolts?
01-31-2019, 02:42 PM #10
Oil pressure sensor
I haven't. not like you're tq them down that much.
01-31-2019, 02:44 PM #11
Oil pressure sensor
I use anti-seize on plugs, bolts that will see heat cycles, or when you have aluminum and steel combo.
01-31-2019, 04:39 PM #12
Thanks man, good information!
02-01-2019, 06:47 AM #13
I'll also add that starting today I'll be adding it to wheel studs as wheel.
Also if you have rotors that stick to hubs, I've done that too.
02-01-2019, 07:58 AM #14
Funny you say that. I had to pound my left rear rotor to get it off. From that point on, I put a light coat of PB Blaster with a rag to keep it from rusting and stay lubed. More good info! Thanks man!
02-02-2019, 10:08 AM #15
02-04-2019, 06:39 AM #16
02-04-2019, 11:47 AM #17
Cool, thanks man! No problem, but when you think about it, the OPSU does go through multiple heat cycles, and is mated from steel to aluminum. Anti-seize probably would not hurt. Those are my auto parts stores of choice as well. Thanks again!
06-23-2019, 01:40 PM #18
- Jun 2019
- US
Now that is blue!
Sent from my SM-G930V using Tapatalk
oil pressure sensor question
By vortex1369 in forum General HelpReplies: 5Last Post: 06-01-2012, 07:47 AM -
Oil Pressure sensor
By mrpckrb in forum External EngineReplies: 7Last Post: 06-24-2008, 07:40 AM -
Oil Pressure Sensor
By CWW17 in forum General HelpReplies: 5Last Post: 04-20-2007, 07:06 AM -
Knock Sensor/Oil Pressure Sensor Issue
By Slow '99 in forum External EngineReplies: 1Last Post: 04-04-2007, 08:28 AM -
Oil pressure sensor
By blomeup647 in forum General HelpReplies: 5Last Post: 04-03-2007, 03:42 PM
